Help with Spice Model vs Real Life
Started by Unlikekurt, February 14, 2017, 11:26:14 AM
Unlikekurt
Hello all,
This is basically a common emitter booster (a la LPB-1) but I wanted a fixed gain of much less for the stage I am working on so R1 is 1.5K and then in order to get the collector set at half supply I changed R3 and R4.
I wanted to add an emitter follower to be able to drive the next stage.
I made a model in spice and i get the results I expected.  However, when i build the unit in real life the results differ greatly.
I still get the VAC output from Q1 that is expected, but the output from the emitter follower is wonky unless i increase the value of the emitter resistor substantially, say to around 33K. And even then the waveform doesn't seem quite sinusoidal.  it is worth noting that in spice I can even have RE as low as say 600R and it models fine.
Any advice or comment would be appreciated.
Re-re-check pinouts.
What is the difference between DC Voltages modeled and built?
Gus
To add to what PRR posted try 2N2222 and the 2N5089 spice models in your sim, compare the sim voltages and real voltages
Is this built on a breadboard? if so check you wiring
Emitter followers can have stability issues
A link to something from 2012 that might be useful http://www.diystompboxes.com/smfforum/index.php?topic=99139.msg868712#msg868712
antonis
Sometimes, simulators may give some "unexceptable" results...
i.e. if you have a signal of, say, 500mV and a gain of 100 you may have on output a 50V measurement, despite of the +9V power supply..  :icon_wink:
bool
Check your transistor pinouts and wiring for errors first.
If your transistor models have different betas than your real-life transistors, the biasing like the one you used can yield predictably unpredictable real-life results.
Once you sort out the "do's" and "donts" with simulations, you can get amazingly accurate results with LTspice. Takes a bit of a learning curve first.
