Consistently failing
Started by Mgt280y, February 22, 2017, 08:29:06 PM
hyrk
Quote from: Mgt280y on February 23, 2017, 02:36:45 PM
Ta-da ........
200gm gloss 100% toner setting
All bar a little ground fill transferred :) just got to get the scummy paper that's left off
Winning !
Bien joué !!
Well done !
My instagram profile : https://www.instagram.com/benumb_/
Mgt280y
Update .....
Board etched and drilled
All looking good but I continuity checked all the trace and ground fill and I have a tiny issue
The L shape trace pad near the 80mm text is still touching the ground fill what's the best way to remove that tiny bit of copper joining the two
Carfeully scrape it with one of those jewellers tiny screwdrivers...then reccheck continuity...
roseblood11
Get a cheap facial scanner from the flea market...
