Aion Helios (Pro Co Rat) Problems - No Signal When Effect Engaged
Started by natron_mn, March 10, 2017, 11:10:42 PM
natron_mn
I'm working on an Aion Helios (Pro Co Rat circuit) and I'm not getting any signal when the effect is engaged. I thought the build was clean and thought it would fire up right away, but no such luck.
One quirk with this, I drilled the hole for the toggle switch slightly off, so the full pcb wouldn't fit into the enclosure. I had to sacrifice the toggle switch to make it fit (I'll just put a sticker or something over the hole). So I put a jumper between the left two pads where the toggle is supposed to go, and figured this would just make the 1n914s always on. I can live without switching clipping modes.
Anyway, I don't think this would cause the issue, right?
I'm using an OP07 IC and a BF244a transistor. My voltages on the IC are as follows:
1: 9.68V
2: 4.83V
3: 4.43V
4: 0V
5: 0V
6: 4.83V
7: 9.7V
8: 9.7V
Do those look correct?
Here are some pics of the pcb:
lukeferg
The IC voltages are fine. Could you please measure the output transistor too?
this:
Quoteand a BF244a transistor
have you checked your datasheet for the BF244? look very close at the pinout, there is a trick. also, make VERY sure those tantalum caps are facing the right way (disregard if the are plcc's) .
I feel sick.
natron_mn
Ahhh, looks like the 5457 is a DSG and the 244A is a DGS. So I have to twist the ends on the BF244a to match, huh?
I'll try that before inspecting all of the caps, but I'm pretty certain I oriented them correctly.
natron_mn
Switched the pinout, and now it's working like a charm! A little bummed I've got a hole in the enclosure where the toggle should have been, but the pedal sure sounds rocking!
This forum is a life saver - thanks, all!
Those holes can be epoxy filled before labelling.
There's some threads about it.
Search?
Rich
thermionix
How do you like the Softness control?  Do you think it would be worth implementing as a regular external pot/knob?
natron_mn
The sweep control? To be honest, I can't tell too much of a difference. It seems to act similar to the existing filter control. I could be using it wrong though. When I have distortion maxed, sweep doesn't seem to do anything.
natron_mn
Sorry, my bad! You were talking about the trimmer. Yeah, still dont notice much of a difference!
thermionix
Gotcha.  I've seen that suggested before but never tried it.  Sounds like it's not worth fussing with.
