Another wooden enclosure.
Started by Purplebuttcheese, March 26, 2017, 04:25:59 PM
Purplebuttcheese
Fuzz pedal built from a PCB I got from eatyourguitar.
https://m.imgur.com/gallery/sZ4M5
There is a Pictures board that would be more appropriate for showcasing your builds.  :icon_wink:
Purplebuttcheese
No worries.  Once you find your way there, you can post some more pics of this latest build of yours and tell us what all those knobs do.   :icon_smile:
http://www.diystompboxes.com/smfforum/index.php?board=40.0
blackieNYC
Is it stomp-worthy? Even if it isn't, it is still very cool!
I've used a couple candy tins, and they were a bit weak, thin. On with side of the stomp I put a stack of Legos for support. Not as rugged as a Hammond, but good enough.
Purplebuttcheese
I've stomped on it a bit. But yes a good support system under it is probably the best idea. Wood splitting and breaking the enclosure would be devastating considering how long the painting took :'(
