Is there any circuits I can do with this transistor?
Started by Purplebuttcheese, April 04, 2017, 07:19:53 PM
Purplebuttcheese
The only markings it has is "DB SS PI 51" on the top and "6846 2N2858" on the side. Here's some pictures I took
http://m.imgur.com/a/I3sgJ
Digital Larry
Looks like a Silicon NPN with a minimum beta of 20!  which is really low.
http://alltransistors.com/transistor.php?transistor=2504
Fuzz circuits seem to like lower betas, but I'm used to seeing people talk about 50, 60, 70 range.  20 is just the minimum beta and who knows what it is really without measuring it.
Digital Larry
Low hfe. Diy Darlington.
Or use as a body diode for clipping.
antonis
Excellent choice for current-pass transistor of a stabilized power supply..
mac
hfe>20, so it could be higher, in the right place  ;)
Besides, it has a low ft compared to another low hfe transistors.
If you can, try to measure hfe.
mac
mac
QuoteGood to see you around Mac.
I'll be back Rich :)
For example, TIPxx datasheet say hfe>15-20, around 60 typical.
I bet this is the case, so it could be used in FF, TB and other old fuzzes.
mac
