EA Tremolo debugging help
Started by OddEddie, May 16, 2017, 04:39:42 PM
OddEddie
Built the improved EA tremolo, sounds good but...... I only have adjustment of the speed pot from 8 to 10, the first 80% does nothing :?  Any ideas on how to get better control?  Any help is appreciated :)
Jack of all trades....King of none
GGBB
Are you using a linear taper pot? Try an anti-log (reverse audio) taper instead. That's usually what causes your problem.
patrick398
I built one of these a while ago, needs 100k reverse log (C100k).  Also, if i remember correctly, if you want more depth you can play around with the 68k resistor going from depth pot to ground. Doesn't get particularly choppy but you can squeeze a bit more depth out of it if you so wish
