Where can I buy Toggle Switch "Bezels"????
Started by jtladsuh, June 08, 2017, 01:49:16 PM
jtladsuh
Does anyone know where to get the mini-toggle switches that sit low inside a "bezel"? (to stop you breaking them by accident) Whether this is a standard mini toggle, that you buy the bezel separately for? or if they come as a unit?
Or, what these "bezels" are actually called? as Google keeps throwing me up nothing relevant.
Examples are the toggles on top of things like Chase Bliss Tonal Recall etc.
I think you are looking for "short bat" toggles (sometimes called "short lever").  What you perceive as a bezel is the threaded bushing.
The pedal you mentioned:
A link to one of these types of toggles available through Smallbear: http://smallbear-electronics.mybigcommerce.com/dpdt-short-lever-on-on/
And, welcome to the forum!
Steve Newton
Quote from: EBK on June 08, 2017, 02:03:49 PM
Also called 'short throw' or 'short stroke', and you're probably going to have to throw mini or sub-mini into the description when you search.
Steve.
Not my circus, not my monkey.
jtladsuh
Thanks so much! I've been lurking here for a while and i knew someone would know.
jtladsuh
[/quote]
Thankyou!
Keep in mind, you can also set those switches lower to get the same benefit (arguably more benefit):
(Thanks go to Thermionix for suggesting this to me.)
mg.audio
I'd sure love to find some PCB-mount mini toggles that would sit low like that...
Quote from: mg.audio on June 08, 2017, 09:29:43 PM
Just mount your board lower.  :icon_wink:
Plumbing aisle. Copper tube fittings. End-cap. Get one big enough for switch *and* finger. Drill it 1/4 or 3/8 to suit your switch. Won't work/break that by accident.
Plastic (PVC) fittings are available but may be too thick to add to a switch bushing.
You could also look for toggle switch guards (they're probably sold under lots of different names too...).
digi2t
If accidental switching is your concern, but you want to keep the bat long enough to be easy to find and manipulate, may I suggest these;
But, for all intents and purposes, short bats, as previously recommended, will be fine. Especially if you can mount the switch low. I have them fairly close a footswitch and/or knobs on some builds, and I've never "accidentally" hit one yet.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
This would be fun on a (big) pedal or amp:
C&K used to sell dress nuts for toggles, but they aren't really high enough for protection. however:
these are dress/protect nuts for pushbuttons, the thread should be standard sized, so these might be the nuts [sorry!].
" I will say no more "
thermionix
#13
Quote from: EBK on June 09, 2017, 09:52:23 AM
I've got a couple of those (without "Nitrous").  I thought it would be funny on my amp, but it just looked silly, so I didn't use it.  Pretty big.  Also if you just lightly bump it when it's sticking up you turn your amp off.
