2SK30 - JFET or MOSFET? (Noob warning)
Started by thermionix, June 15, 2017, 01:46:00 AM
thermionix
So I built the Geofex JFET Vgsoff matcher.  But I don't have many JFETs on hand to sort through, just a few each of a few types.  Checking Tayda I was a little surprised at how expensive JFETs are, so I started looking for lots on Ebay, various types.
I'm not yet committed to building a Phase 90 or 45 at this point, but I'm using those circuits as a guide.  I read several threads about them here, and one recommended JFET sub seems to be the 2SK30.
Found some on Ebay from China for a good price, but they describe them as MOSFETs.  Google search brings up mixed results.
JFETs and MOSFETs are two different things, right?  Or is a 2SK30 both?  If it is a MOSFET, is that still a good sub in the Phase 90?
Okay, secondary question.  I was testing some of the JFETs I have to make sure the tester I built worked.  Most were giving me "typical" results, like 1.6 or 2.4V...seems the tester is working.
But then I grabbed four NOS NTE458s I have, and the test results ranged from .03 to .05V.  Is that right?  Pretty radically different.  I'm sure I had the pinout correct, it's printed on the NTE package.
JFETs are expensive now because they are obsolete and becoming rare.  The 2SK30 is indeed a JFET, not a MOSFET.  The two are quite different and you can't generally sub one for the other.
thermionix
So, probably best to not buy from this seller...
http://www.ebay.com/itm/10pcs-2SK30A-GR-MOS-Field-Effect-Transistor-TO-92-/191548242371?hash=item2c992a39c3:g:l9QAAOSwrklVDOBG
The price seems nice though.
Seems the datasheet google results I was getting were of pages that had more than one type of transistor, so it looked like they were confirming MOSFET until I looked closer.  Like info for 2SK3069 was showing up instead.
Thanks for the reply.
You know what they say about "too good to be true"?   ;)   But for only two bucks, I'd be pretty tempted to give this a go.  Ya never know, ya might strike it lucky...
Quote from: bluebunny on June 15, 2017, 02:42:36 AM
Surface mount JFETs are still readily available and cheaper. Carefully tack some leads on or solder them directly to veroboard strips and you're good to go. I admit, it would be a much bigger pain in the butt to go through a matching process with a pile of those....
(Of course, my solution is simply to not build phasers  :icon_razz:)
about your linked ad at the popular auction site - the part in the photo shows all the right stuff for a 2SK30A-GR, but seller then goes and blows it by claiming they are 2SK30A-Y. Y and GR are different "gain bukkets". I'd ignore his "mos" ref.
K30A is a valid search term. tayda have K117 for 0.20 out of stock which would have been adequate, so you could skip over to futurelec for a lookie - I can vouch for their K30A's, but everyone here will tell tales of woe about their speed of delivery and response.
see:
http://futurlec.com/TransMos2N.shtml
I feel sick.
thermionix
Quote from: EBK on June 15, 2017, 06:01:31 AM
Yeah screw that.
Quote from: thermionix on June 15, 2017, 04:35:28 PM
Yeah screw that.
Screw surface mount?
:icon_razz:
thermionix
