moog MF 104Z delay turned completely silent
Started by Frances Rhodes, June 19, 2017, 01:36:26 PM
Frances Rhodes
hi everyone
i bought an "old" MF 104Z (serial #0288) and i've had some problems with it.
it worked well until it started to pop really loudly when switched on and off, until it finally turned silent.
i opened it, checked the jacks and they all work fine, no broken connections, no wire unsoldered.
i tried the delay only output, and it works as a charm, only the mix output is silent.
also, every control works as it should.
i contacted the moog tech guys because i cannot find any moog licenced repair center around. when i told them about the loud pops i heard when i switched the pedal on and off they thought it might have been a faulty Cmos (used as a switch). i did replace it with a new one and nothing changed.
then, a few weeks later, it finally "died", so i came back to them and they thought it might have been the OTA driving the output that fried, which could have explained the pops, but didn't say much else. i looked and there are maybe 6 different LM13700s in there, and by then they didn't tell me what chip was the output OTA so i could try to replace it.
i bought a new LM13700 but had to let the MF aside for a while because life happened, now that i finally have time again, none of the emails @moogmusic work anymore and i only get delivery failures.
would there be anyone here knowing what LM13700 is driving the mix output, or anyone knowing how i could check all of them to see if one is dead (preferably without removing every one of them)?
thanks in advance,
regards
frances
"If it's too loud, you're not too old, it's Alancka Effectors."
https://www.facebook.com/alancka.effectors?sk=info
Six different LM13700s?  Is that a delay or a phaser?
Frances Rhodes
#2
it's the delay!
EDIT: there are 4 LM13700N chips in there.
2 are close to the jacks and 2 others are close to the MN3101, i guess those are for the active low pass in the delay loop.
Ah.  I gather the OTAs are used for the external voltage-control of things like delay level and feedback, and/or tracking lowpass filtering (to get most usable bandwidth for any given delay time).
Another naïve question:  You wouldn't happen to be using it in a series of pedals would you?  Or does it pop when used entirely on its own - just you the guitar, the delay, and the amp, with nothing else in between.
Frances Rhodes
yes, there are CV inputs on the rear panel: feedback - time - mix, one OTA is probably there for the feedback, you're definitely right!
i had pop problems with other pedals before so with the MF, i tried it in series with other pedals (at the end of the chain, just before the amp), then alone, with different amps, different instruments (several guitars and a fender rhodes piano), several cables (factory made and hand made), i even tried it with nothing going into the input, and it poped all the time. the only thing i couldn't change is the power supply because i don't have a spare one.
but only the mix output poped (before turning completely silent), the delay only output never poped, and still works fine!
