modding RGs parametric EQ for dual supply operation
Started by tempus, June 25, 2017, 01:01:40 PM
tempus
Hey guys;
I've built a 5 band version of RGs parametric EQ
I have a prebuilt dual +/-15v supply in a case that I'd like to mount it in. To adapt this circuit for dual supply, is it just a matter of connecting all the grounds to -15v and all the Vb+ to ground?
No.
Chip pins 4 go to V-. All other grounds go to zero V.
tempus
Thanks for your reply PRR. There are also connections to Vb+ (i.e., V+/2). Do they also go to 0V?
Thanks again
mimmotronics
PRR is correct. All pin 4s on the 5532s go to -15V. Vb (I'm assuming is the reference voltage) goes to 0V.
tempus
Yes, Vb is the reference voltage.
OK I'll give it a try. Thanks for the replies guys
