Mic MUTE pedal
Started by Buffalo Tom, July 17, 2017, 01:49:13 PM
Buffalo Tom
Is this wiring correct? Its for a violin with one phantom powered microphone on XLR and one contact mic on TS cable. So when switch is pressed I want the audio to be muted on both outputs but the phantom power supply should be constant.
I would just short XLR pins 2 and 3 together.
Buffalo Tom
Quote from: PRR on July 17, 2017, 09:13:16 PM
But isn't that what i'm doing in my wiring? Thanks
I would *JUST* short XLR pins 2 and 3 together.
Not leave OUT pin 2 floating.
The 48V coming out of what gets OUT won't know what to do.
Buffalo Tom
#5
Quote from: PRR on July 18, 2017, 09:14:57 PM
The SHURE circuits are even better.
mck
Hi,
Buffalo Tom, did you succeed with your mute ?
Could you eventually post the wiring schema you used, please ?
(the schema in your first post is very understandable for a newbie like me  :) )
Thank you very much
Isn't this really a job for the Burst Box?
mck
I tried this one, and it's great.
