how to implemen a lfo led into Bloodstone Phase Shifter (EHX Bad Stone™ Phaser )
Started by njkmonty, July 19, 2017, 07:38:09 PM
Scruffie
Try a diffused LED from pin 8 of the 324 with a 4k7 to ground, if that works but doesn't turn 'off' enough, add another 4k7 in parallel with the LED.
If it works but messes up the sweep you'll need a transistor buffer.
njkmonty
cheers , i was playing around with the 324 legs but couldnt get any throbbing,  i will give you suggestion a go!
thanks
njkmonty
no good, i couldnt even get any voltage variation at all from pin 8,  bummer, none of the other pins or rate pot legs etc had any voltage lfo changes i could find
Scruffie
No moving voltages at all? This might seem like a silly question but, you weren't in manual mode by mistake were you?
njkmonty
njkmonty
got it working!   yes you were right  i didnt work on either setting, i was using the wrong resistance range,  it turned out  that 82 ohm resistor gave me they best throb.
thanjkyou!!
i just connected the resistor to the leg of the transistor which connects to the pin of 324 you suggested,, thanks again!!!
