When double checking isn't enough
Started by vigilante397, August 09, 2017, 04:41:44 PM
I finally decided it was time to take another step in build quality so a few weeks ago I ordered some boards from OSH Park. All the boards I ordered were modified versions of things I had built before, but with double-sided boards, tighter traces, and solder masks I re-did all of my layouts so I could make the boards smaller, do board-mounted pots, move in/out pads to more convenient places, etc.
The boards came, and they looked fantastic. But much to my dismay, upon soldering them up, a couple of the designs didn't work! Proposterous, I thought, I've used almost the exact layout a dozen times, how could it not work? Well, upon poking around with a multimeter and an audio probe, there were a few places on a few boards were I either connected the wrong things or I just forgot to connect things! I was following the schematic, but the same eyes that made the mistake can't really double check for mistakes.
So where am I going with this? Linked layout/schematics. There are plenty of options out there (Altium, DipTrace, and I think Eagle) that will allow you to link a schematic file to a layout to make sure you aren't making stupid mistakes on your layout. When you first import it everything will look like a huge mess, but it sorts itself out to a neat, working layout.
So I'm out $50 or so (I think, still have a couple boards I haven't tested), but I've learned my lesson and hopefully will get back to building pedals that work :P
Hatredman
Yes, Schematic Capture is a must. It's really more than three or four times  the work compared to simply tracing the layout directly, but it pays.
And you can use autoroute in sone cases.
Scarlett Johansson uses a Burst Box with her Telecaster.
Kirk Hammet invented the Burst Box.
Quote from: vigilante397 on August 09, 2017, 04:41:44 PM
True, Correct and Verified...!!!  :-[
karbomusic
That is the primary reason I switched from Vero to say Eagle and etching. I could achieve "almost" the same success rate with Vero but the quintuple checking node by node, point by point, increased the build time by multiples. When linked, so long as I don't make a mistake when I breadboard and test the schematic, it almost has to work when etched.
Digital Larry
I've used VeeCAD with Vero and it works pretty well.  Little weird to get started with.  I even paid for the deluxe version.  Recommended if you are going to go beyond copying designs.
Digital Larry
I'm not familiar with VeeCAD. It looks like it's designed with vero and perfboard in mind, am I understanding that right? How are you liking it?
