JFET Vulcan Experiment some hints needed :/
Started by KarenColumbo, August 16, 2017, 03:01:18 PM
KarenColumbo
#20
In my neighbour's workshop. Colour is called "Carrot". Hmm ...
I see something of myself in everyone / Just at this moment of the world / As snow gathers like bolts of lace / Waltzing on a ballroom girl" - Joni Mitchell - "Hejira"
KarenColumbo
#21
There's still a question remaining, I can't seem to get my head around this:
There'll be 2 LEDs in there. One of the two stompswitches (3pdt) switches between the two gain levels - AND between those two LEDs. The other (SW1) is the usual bypass stomp.
In theory I would wire it like this, wouldn't I?:
certainly, that is one workable arrangement. I also use airbrush for all my painting - a little bit of paint and a looooooot of water. takes a long time to get a decent coat on.
" I will say no more "
KarenColumbo
I took the fast way - nitro. It's bad for the invironment, but I compensate by wearing fair clothes only :) Plus it dries in a whiff (3-4 hours)
KarenColumbo
Thing is coming along.
Optimized the PCB for less space:
Drilled and soldered
Pot fitted. Alas, not really centered. Next time I'll build the whole shebang AROUND it.
Daughterboard: Power filtering, Millennium 2
Fits quite nicely. Of course I drilled the box without proper measuring and without a drill template. Will do better in the future
Next: The least fun part (at least for me) - wiring. I will need beer for this.
KarenColumbo
One important thing:
I'm about to wire it this way (I left out the power connections +9V and GND from MIL 2 daughterboard to PCB to not add to the confusion):
My questions are:
1. Is it vital to connect ALL ground cables? At the moment there's ground connection from In-Jack to PCB-In AND 3DPT Switch, and Out-Jack to PCB-Out. Do I have to connect the 3DPT ground pin to the output jack, too?
2. The two LEDs have their grounds connected to the Millennium 2 daughterboard. Should I ground them to the PCB, too?
your circuit diagram - anything shown connected to ground needs to be connected to ground. how you do it is up to you. you can lassoo all the non-audio grounds and connect them together, then to ground, and all your audio grounds together, and then to ground, but they all need grounds.
