Speaker question
Started by joakinrox, August 23, 2017, 03:17:40 AM
joakinrox
Hello!!! I'm planning on building a combo punch amp, but the enclosure I'm planning on using can take a speaker of up to 5", so in your opinion which of these options would sound better?:
  • a 5" guitar speaker (like a jensen mod 5 for example
  • a stack of four 2" full range speakers (amplified through a cab sim like cóndor)
Also, do you know of any other 5" or smaller guitar speaker?
The MOD 5 is a kick-butt speaker for its size.
While I am a fan of many-speaker arrays, I can't think of any Twos that, quadded, would approach the MOD 5.
seadi123
#2
Do not use HiFi speakers, they will never sound good and you will hate your amp immediately
Go with the 5"speaker.  You have 1.5625 times the cone area and 0.625 times the surround length so you will get better bass and less Doppler distortion and probably better sensitivity.
Quackzed
i revamped a pc 'bass' speaker into a nice little guitar amp, it had 2 sattelite speakers (removed) and was the sub (lol) for the little 3 piece setup,was also a 5" speaker,box was about 7x7x7 and had a little port. the secret of it sounding so big was that the little enclosure size with the right length port had a resonant frequency of @ 95 hz  not far off from a 4x12 closed back 'stack' type cab. and it did have a little of that 4x12 oomph.
so if you close up the enclosure and add a port you can tune the resonant freq to add some low end,works a treat for the very small amp speaker setup.
