Show Your Letter Stamped Enclosures
Started by swever, August 28, 2017, 11:28:20 AM
Benoi31
Do you have an example of a "good" letter stamp set?
I tried several times with the one I bought, but could not really manage to get some decent results with it.
swever
Hi Benoi31,
Did you have a heavy base directly under the stamped surface? If not, it's the most likely reason for unsatisfactory results.
I bought the cheapest set I could find and it seems to work fine. The only thing that's not great about it is that some letters' stamping surface aren't exactly perpendicular to the letters' shafts. Which means you have to hold the stamps and hit them "at an angle" which is not so cool.
roseblood11
That's amazing! Your stamps are made of Lego!!
T.
thermionix
Yeah, what are those?  Why aren't they backwards?  The letters on the wood veneer look burned in.  From behind?  I'm confused.
Plexi
#25
Maybe it's the upper side (where you hit with the hammer)
That way its easier to not lost the orientation.
To you, buffered bypass sucks tone.
To me, it sucks my balls.
Quote from: thermionix on December 01, 2017, 04:49:51 PM
I'm going to guess that's not the stamping side of the block we're seeing, you can snap them together and easily read the word and know it's going to stamp correctly.
dave
Quote from: Plexi on December 01, 2017, 06:30:27 PM
I think so too.
dave
I'm guessing they are letter press (ink) stamps.
thermionix
Quote from: davent on December 01, 2017, 06:31:08 PM
dave
Duh.  I'm sure you're right.
Quote from: roseblood11 on December 01, 2017, 12:46:52 PM
Beginners version  8)
I dunno what it is, but I think it's great. and an orange led.
[.... nvmd ....]
roseblood11
Quote from: thermionix on December 02, 2017, 12:14:57 AM
dave
Correct. I stole them from my son...
swever
garyg
Quote from: swever on August 28, 2017, 11:28:20 AM
Here's my first attempt. Cyrillic letters ftw :)
I like this look a lot, nice work.
What size are these stamps? I've seen different ones from 4mm up to 11/12mm. I guessed maybe 8 but too big? Looks like some are measured by the size/width of the shaft not the actual letter. Thanks.
swever
Quote from: garyg on February 28, 2019, 09:05:16 AM
Thank you and sorry for a very late reply. Been away from building and the forum for over a year. I used 4mm stamps.
swever
Here's a new one that I finished yesterday. It's a slightly modded metalzone
ManicStrat1982
Quote from: swever on January 27, 2020, 11:50:22 PM
That's bad ass!
jmwreck
#37
Here's my Blueberry Bass OD
and the Barbershop
