delay + modulation switching problem
Started by alange5, September 14, 2017, 05:06:56 PM
alange5
I built a Deep Blue Delay and added a modulation board.  The modulation is wired to a 3-way switch (half of a DPDT on/off/on) and should yield the following:
(1) up: modulation only
(2) middle: delay only
(3) down: modulated delay
Positions 1 and 2 work great, but I'm not getting any modulated delay in position 3 - just normal delay (same as position 2).
Here's a crude drawing showing the two boards and my switch wiring:
If I disconnect lug 1 from the main delay board, I do get modulated delay in position 3, but nothing (dry clean signal) in positions 1 and 2.
How can I wire the switch so that lug 1 is connected to the main board in positions 1 and 2, but disconnected in position 3?
Any other suggestions are welcome.  Thanks in advance.
jonboper
Did you figure this out? (I don't know the answer, was reading through posts and this was 4 pages deep...)
