Build a (Tayda) RAT.
Started by italianguy63, September 30, 2017, 05:14:26 PM
italianguy63
Picked up this Tayda PCB on a flyer... PN#  A-1552
For $8, it is a nice board... well laid out.
To make it totally legit--
Substitute C12 from .47uf electo cap to 1uf electro (unimportant)
And use a LM308N OPAMP instead of the TL071.
I will post pics when I eventually put this together and do an enclosure...  MC
thermionix
Did they have the comp cap in there with the TL071?
italianguy63
Looked to me they merely swapped the LM308N for the TL071,
The other sub was in the power supply filtering...
MC
thermionix
If you soldered in a 30 puff cap, then it's there.  They must have anticipated people using LM308s, because that cap would go nowhere with a TL071, pin 8 is NC.
italianguy63
italianguy63
The 30pf is there.. from Pin1 to Pin8 of the IC.  Same as the "real" schematic I have for the RAT.  (w/LM308N)
MC
italianguy63
Quote from: thermionix on September 30, 2017, 06:15:03 PM
They probably subbed the part because Tayda does not sell LM308N's.
thermionix
Right on, good to know.  I used one of their 808 boards, no problems.  My only complaint is that they should post a schematic on their build instruction page, with their component numbering scheme.
italianguy63
Quote from: thermionix on September 30, 2017, 06:34:14 PM
Yep!  I compared the original to the board.. the component numbering was ALMOST spot on.. made it pretty easy... I did not trace it out totally since it was so close.  But, I think this one is a big winner with the minor tweeks.
MC
bamslam69
My next build, a Rat.
Doing lots of googling, found some of BeavisAudio's mods, so I'm going to have some fun with this pedal. Might build one stock, and one with bells & whistles.
Thanks for the previous tips with the 308. (I'll grab some cheap 071's as well).
There's a schematic on the project page now.
Yeah Nah - Nah Yeah
italianguy63
Wow... 4 year old thread...
I did end up developing a 1590B version of the original PROCO RAT and did a PCB.  I have them if anyone wants to try one.
I also have a mini 1590A version too.
Some pics of the 1590B version:
iainpunk
hmmmm, i never actually build a rat.... well, come to think of it, never even build any opamp and hard clipper circuit to full completion,,, dont know if i need one, but i think i should out of respect or something like that
bamslam69
Quote from: iainpunk on November 10, 2021, 06:13:46 PM
Yeah, something like that too. It's just a matter of having something to get my hands dirty with.
Yeah Nah - Nah Yeah
cab42
Quote from: bamslam69 on November 10, 2021, 05:53:59 PM
I built mine with a 741 first as it was what I had, then I got hold of a OP07, but now it has the proper 308 inside.
As far as I recall, there wasn't much difference between the 308 and OP07, but I lost my OP07 so did not do much testing. The 741 also sounded cool, but different.
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
iainpunk
i had a rat on a breadboard for quiet a while, even did some blind testing with chip swapping and letting guitarists state their opinion. no one of the people i tried it with heard any significant difference between the 308 and the 07, but most of them guessed one of them to be the 741, and most of them thought the 741 was the 308... i think ill build mine with an LM3900 i read about yesterday
Ben N
Quote from: italianguy63 on November 10, 2021, 06:02:44 PM
Truly a Rodent of Unusual Size.
the only one I've ever built was with an LM307. that would be a rare beast these days, I'm sure.
an LM3900? what are you going to use the other three opamps for?
" I will say no more "
mwelch55
I built a Tayda Rat a couple of years ago.  I made it with all of the correct values.  I installed a 12 position rotary switch with all of the diode clipping options I could thing of.  The first position is without clipping diodes.  It makes a really good clean boost.  My Rat pedal is one of my favorites.
iainpunk
Quote from: duck_arse on November 11, 2021, 09:25:35 AM
input buffer, output buffer and buffered Vb
mdcmdcmdc
Everyone needs a rat or three!
