Output/sound issues on a Boiling Point build
Started by Ambugaton, October 01, 2017, 04:57:59 PM
> saying that the emitter on both MPSA18's should be about 0.7V lower than the base?
In operation, yes.
*When poking with a meter*, the bases are fed with a very high-Ohms resistor. Nearly as big as many meters' input resistance. So *while poking* the voltage is lower. While we could calculate the loading (if we knew the meter specs), if that stage has a happy emitter voltage and passes signal, I'd overlook a "low" base voltage.
Ambugaton
Quote from: PRR on October 06, 2017, 01:58:55 PM
Just got done searching through the forum and found: http://www.diystompboxes.com/smfforum/index.php?topic=113139.msg1046366#msg1046366
Thanks.
