EDN article on JFET distortion pedal
Started by BubbaFet, November 10, 2017, 09:19:43 PM
You can make a distortion with a JFET?? Wow, who knew that?
(Maybe those strange dudes Jack and R.G. in the References?)
I do note that the "0.5 V peak-to-peak input signal" is really 0.5V peak.
Also "high input impedance of the circuit makes it a good match for the output of an electrical guitar" should be "fit" not "match".
Reference 1 has a serious over-simplification. Ref 3 has flaws, but I did not go-on to Part 2.
BubbaFet
amz-fx
thermionix
Quoteyou can take your distortion pedal effects devices off the grid with just an everyday battery.
The 1960s have finally arrived!
Frank_NH
Hmmmm...this is actually very interesting.  Two matched low noise N-channel JFETs in a 6 or 8 pin package.  I wonder how much lower the noise is compared to a run-of-the-mill 2N5457.  May be worth playing around with - a Dr. Boogie with LSK489 chips anyone??
