Real inductor multiplier
Started by mac, November 18, 2017, 02:12:01 PM
mac
I need a simple circuit to multiply the value of a real inductor, floating or grounded.
>--()()()()--circuit--()()()()()()()()()()()()-->
I'm googling but I see only gyrators.
mac
You might be able to find something under the field of instrumentation.  Maybe for LCR calibrators.
I do remember some tricks multiplying and dividing resistances for the old computer joysticks.
The general circuit for the grounded case is,
            input  ->   Buffer   --> divider  by k  -->  Buffer
The inductor connects to the input (of the first buffer) and the output of the second buffer.
The idea is to reduce the current through the inductor in a way which is opposite to the Miller effect.
If the input voltage is V  the voltage across the inductor is V*(1-k).
The current through the inductor will be I_L = V*(1-k)/(sL)   ; s = complex frequency
So the impedance to ground looking into the input is,
Z   = V_in / I_L  = V / [V* (1-k)/(sL)]  =    sL / (1-k)   = L_new
Where L_new = L/(1-k)
so when k is just below 1 you get a large inductor.
I suspect trying to multiply by 1000 is going to be a disaster but you might get away with x10.
That's the idea.   I don't know what evil behaviour the circuit has when you start considering stability and
limited opamp bandwidth.
If you use a high-impedance divider before the first opamp you can remove  the second opamp.
In the back of my mind there might be a way to do this using the idea of a current divider.   Maybe what I posted was it. Let me think about it.
OK, here's yet another way using the method I mentioned above,
http://www.seekic.com/uploadfile/ic-circuit/s200971231137907.gif
Here's the way using a the current divider,  (Section, Higher-Ratio Impedance-Multiplier Circuits )
http://www.tubecad.com/2009/09/blog0171.htm
mac
#3
Thanks Rob,
I'll run a spice model before going to the breadboard, and report back.
Quote>--()()()()--circuit--()()()()()()()()()()()()-->
There is an error in my drawing. I mean this,
>--()()()()--circuit-->   =   >--()()()()()()()()()()()-->
mac
