Adding passive Blend/Mix pot to Electric Mistress' circuit. How?
Started by Longer713, December 09, 2017, 03:24:42 PM
Longer713
Hi guys!
I'm thinking about adding blend or mix pot into Madbean's Current Lover circuit which is clone of Electric Mistress.
It would be great if I could use for that 9mm Alpha pot. Is it possible to add it similarly to how it's done in tonepad's CE-2 blend mod? Just toss a pot in series with resistor? I know there are active blend circuits  but due to not much space in enclousre I would like if possible stick to passive way.
I was thinking about mixing dry signal before it goes to PCB's input. Am I wrong?
Schematic:
http://www.madbeanpedals.com/projects/CurrentLover/CurrentLover_2015.pdf
Highly appreciate your help.
