3 Loop Switcher with Order Swap of Loops 1 and 3?
Started by natron_mn, December 21, 2017, 11:01:20 AM
natron_mn
I have three dirt pedals on my board - Jackson Audio Prism, SS/BS Mini and a Chase Bliss Brothers - and I want to be able to swap the order of the Prism and Brothers via a footswitch.
Is this possible without using a digital chip? I'm racking my head trying to think of how to do this, but I don't know if it's possible. I would somehow have to insert the Mini in between footswitch swapping the order of the Prism and Brothers.
Or if I use a 4PDT, could I someone insert the Mini onto one of the sets of poles instead of using a fourth pole for LEDs?
GGBB
I think you want to make A>B>C become C>B>A - is that right? You can do it with a 4PDT switch but no LED.
As there is no grounding or pull downs of signal ins or outs, I'm not sure what kind of noise this will make when you switch. Presumably the pedals themselves will have pulls downs which should help. Ground the connectors if they aren't grounded by enclosure contact.
natron_mn
That's exactly what I'm looking for, GGBB - thanks!
