Troubleshooting with ibanez 808 screamer
Started by airguitar, December 26, 2017, 07:52:38 PM
airguitar
So i made this build for vero http://www.sabrotone.com/?attachment_id=1403
I put everything on the veroboard and i tested it first without volume tone and drive pots.I had sound but zero distortion.Then i tested it with drive and volume pots and i had some minimal distortion wich was really low.I guess the fact that i have sound its good but its nothing like a screamer.What should i do? If it worked well i would have had distortion even without the pots right ?
Plexi
Post some pics!
Maybe there's some shortcut around there.
Which diodes do you use? Gain pot?
To you, buffered bypass sucks tone.
To me, it sucks my balls.
airguitar
Drive pot is 500k log and diodes 1N914
Here are some pics
AS74
Check for solder bridges.  From the photo it looks like there might be one or two.  What I do is run the hot soldering iron between each copper track.  Some solder bridges are minute.
Also check that all track cuts are done.  The cut under R13 could be easily missed.
I would put all the pots in the circuit.
airguitar
Thanks guess i ll check all the soldering again.
airguitar
#5
i soldered all the pots and checked solderings still no distortion  :(
The thing is i get sound from amp just no effect wtf i am desperate
Slowpoke101
Change the capacitor C8. It is supposed to be a 1uF (same as C2).
You have a 100n installed instead of a 1uF.
Change it and see what happens.
stallik
R1 & R3 seem to be in the wrong place and I can't make out what's going on in the R5 area
airguitar
Quote from: Slowpoke101 on December 27, 2017, 12:47:48 PM
i changed it still nothing :/
airguitar
Quote from: stallik on December 27, 2017, 01:56:02 PM
they re in the right place i checked many times they re a little twisted.
my concern is the cold solder joints i think i see 2
