Need help finding a 6P3T rotary or toggle switch
Started by dave999z, December 27, 2017, 11:21:06 AM
dave999z
Hello all -
I am getting ready to wire up a true bypass looper pedal.  It will have 14 footswitchable loops.  There will also be one passive loop (no footswitch) between loops 7 and 8 to connect to my amp using the 4-cable method.  (Loops 1-7 will be in front of the amp, loops 8-14 will be in the amp's effects loop.)
However, I would like to make the passive loop moveable, so that I can select whether it is located between loops 6-7, 7-8, or 8-9.  Even just having that much flexibility would be hugely helpful going forward.
In order to wire that, I need a 6P3T switch.  It could either be a rotary, or toggle, or something else.  It needs to be somewhat low profile (especially if it's an external switch because my back panel is a bit cramped, but I could go with an internal "screwdriver" type rotary or even DIP switch i stead).
If anyone has any suggestions on a quality switch that could work for this purpose, please let me know.  So far I've only seen those multideck rotary seitches that are quite large.  Thanks in advance!
(You know, as I'm writing this, I'm thinking an internal DIP switch wherein each physical switch is a DPDT would be quite simple to wire.  Maybe that's the way to go.)
Cheers.
dave999z
I think I could just use 3 of these:
https://www.mouser.com/productdetail/switchcraft/46206lrx?qs=ReZUMDdiXnQuv6mmQGGqFg%3D%3D
But I'm not sure how I'd mount those inside my enclosure?  (i.e., what do I screw them to?)
Quote from: dave999z on December 27, 2017, 12:13:59 PM
Those switches can be mounted against the inside of your enclosure, with a rectangular hole just big enough for the sliding part and two drill holes for the screws.  The screw heads will be on the outside of the enclosure.  Hope that makes sense.
Hmm... I just reread the question.  Sometimes you can find this kind of switch with tapped mounting holes on those flanges.  Otherwise, you'd have to put a nut on the back, I suppose, if your screw threads aren't right.
dave999z
Thanks, that makes sense.
I'm also wondering if one of these would work (there are two different types):
http://www.switchcraft.com/Category.aspx?Parent=655
Seems much lower profile.  But the specs provided don't have enough detail.  Not sure if these have DPDT function.  And it seems like it may be possible to configure so that only one switch can be depressed at a time (i.e., if you press one, the previous one pops out), which would be great.
Take a look at pp. 301-317 of this doc:
www.switchcraft.com/Documents/EDG4.pdf
dave999z
#5
So helpful...  Thank you!
I think I'm going to make the passive loop assignable to one of five (instead of three) locations:  between either loops 5-6, loops 6-7, loops 7-8, loops 8-9, or loops 9-10.
So it looks like I need a series 6500 switch with "interlock" function.
I'm not sure what is meant by "max 2-C switching per station" versus "max 4-C switching per station" on this page...
http://www.switchcraft.com/productsummary.aspx?Parent=451
I also wish they gave the dimensions.
I was a bit confused by the 2-C or 4-C thing too.  I think it just means double-pole or 4-pole.
Actually, p. 307 of that doc describes the contact arrangements.
Dimensions are in the drawings.
dave999z
#7
I was thinking maybe it means 2 contacts or 4 contacts, but that doesn't make sense for a DPDT switch (which should have 6 contacts).  Hmmm.
But I think you're right, based on this, where it says "Maximum switching per station is 4-C (4PDT)"...
https://www.digikey.com/catalog/en/partgroup/65000-series/35009?mpart=65061K206X&vendor=137
4PDT would require 12 lugs per switch though, and none of the pictures look that way.
To add more poles, they just make the switch longer.  P. 309 shows what that looks like (top center of the drawing).
Or, for the leaf switches, they add more leaf switch stacks (e.g., two side-by-side above the actuator and another two side-by-side beneath the actuator).
dave999z
You're right, it's all in there.  (I was just too impatient.)   :icon_redface:
I really would like a 5-station one, but it looks like odd numbers are custom orders.  Since I was waffling between 3 and 5, I'll probably get a 4-station one.  Which would be model number 65041K206.
Thanks very much.  I really appreciate your help.  I think this will work out well.  So I'll basically wire one of the stations between each footswitch.  When the particular switch is "out" it will just jumper (to bypass the station).  When a particular switch is "in", it will route the signal to the passive loop.  In order to connect them all to the passive loop I'll have to daisy chain the "in" positions together (if that makes sense).
(Relay and) Switch-geeks have their own lingo.
https://en.wikipedia.org/wiki/Electrical_contacts
http://www.ni.com/white-paper/4453/en/
What you or I call "DPDT" can be called "2 form C contacts". And of course when you are hip, you drop the "form" and "contacts".
Though I didn't see it stated anywhere explicitly, I sort have the sense that the question was asked about a 6P3T, based on the assumption that if a 3PDT switch is used to engage a "loop" of a single effect in a pedal, and provide a status LED, then 3 poles would be required for what the OP had planned.
HOWEVER, the need for a status LED and third switch pole in pedals arises from the fact that the switch itself looks exactly the same, whether in effect or bypass mode.  The LED is there to tell you that, despite the fact that the switch looks exactly as it did a moment ago, it is now in effect mode.
When one uses any sort of switch that provides a visual indication of the state, no status LED is needed, unless the user/ manufacturer has some requirement to be able to discern the switch state from a distance.  If one is close enough to see the switch, its position provides all the state information one needs.  Long-handle toggles and rotary switches fall into this category.
One will need a suitable knob to deliver the "state" information.  Probably the best choice for this task is the venerable chicken-head knob, whose ppointer can be nicely lined up with legending.
I will note in passing that Ibanez used a rotary switch for their UE-400 multi-FX rack unit, calling it the "Insta-patch" system.  IN their case, there were only 5 "stations into which a given effect could be inserted.  You will note there is no status indicator provided, other than the position of the switch. Probably could have used a better knob for the task,
dave999z
Quote from: Mark Hammer on December 27, 2017, 09:46:42 PM
When I was thinking of using a rotary switch, I was not planning an LED indicator.  The passive loop is always active (unless there's nothing plugged into it, in which case that jack just shunts the signal onward).  The only thing the rotary switch would do is set the location of the passive loop.  And that is something I'd change once in a blue moon and do not need any visual indication of the current state.
But to switch a circuit among three locations, you need one pole for the input and output side of each location.  So two poles per location, times three locations, equals 6 poles.  That's why I was looking for a 6P3T rotary switch.
But I decided to use one of the Switchcraft multiple station pushbutton switches (see above) instead.  I think it should work fine.
http://www.ibanezcollectors.com/gallery/albums/userpics/18397/UE400_SVC__pg_08x.jpg
This appears to be a 3 pole 5 throw switch, less than I expected. Pole 3 is for a "mis-set LED"; ignore that and you could do a 2-pole 6-throw, which is a standard rotary.
But I have not absorbed what they are really doing with the buses and switches. Mixed with JFETs but they may just be bypass, not order-switching? Too cold to see straight. Some northern land is sending all their spare cold air here for the next few days.
Chris S
eBay is your friend https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F391277360192 I have used one of these in a pedal. They do disconnect before reconnecting when you switch so you'll get pops if changing the rotary while using the pedal.
Quote from: PRR on December 27, 2017, 11:44:07 PM
The "miss-set" indication is essentially a failsafe mechanism, such that all effects/stations in the unit are always in series and never in parallel.
The cure for that is attention and conscientiousness.  It lets one drop a pole from the switch.
Quote from: Chris S on December 28, 2017, 08:10:25 AM
.......  I have used one of these in a pedal. They do disconnect before reconnecting when you switch so you'll get pops if changing the rotary while using the pedal.
so, Form C, non-shorting, or break-before-make. the non-pop, Form D version could be called make-before-break, non?
" I will say no more "
There is really no difference between a stompswitch and a break-before-make rotary, with respect to avoiding popping.  Just do for the one whatever you do for the other.
dave999z
I don't see how you could move a loop around using a 2P6T switch.  Well, I see how you could move a loop around, but it would leave the other five non-selected circuits disconnected.  When a given signal is not the one being "interrupted" by the passive loop (which is connected to the two poles), it needs to be jumpered so the signal will still flow through it.  A 2P6T switch would indeed let you move a passive loop around among six different signals, but at any given time the other five signals would be disrupted rather than jumpered.
Unless I'm not understanding the switch functionality (entirely possible).
