Vintage Fender Footswitch Undrilled Enclosure
Started by Dares, April 25, 2018, 09:38:33 AM
Dares
Can't get my mind off of it,
One of a future build must be done with one of those Vintage Fender Footswitch, because they look so cool !
Do you have an idea where I could find an undrllled one ?
Hours of research, no luck...
Grateful for any hints !
I understood "vintage Fender" as the teeny cake-dishes, not rounded boxes.
I would assume the "dishes" are stamped and punched in the same factory, possibly in one operation. IAC that factory is now on the other side of the world, not a side-street in Fullerton Calif like in 1959.
Any good car body fixer can take a holey footswitch stamping, weld up the holes, grind flat; then send it out to be fine-finished, stripped, and re-chromed. Same as restoring a fender or bumper on a vintage collectable car. Will cost a LOT.
If it does not have to be totally foot-proof.... whack and rasp a block of oak to that shape. Get hobby aluminum sheet and a ballpeen hammer. Start tapping. Quite amazing work can be done this way. Whole Italian cars! But good work may only happen after a 7 year apprenticeship....
QuoteCan't get my mind off of it,
What about using a metal pie dish or one of those metal dog/cat bowls?
Peavey used pressed metal footswitches at some point.  The pressed metal edge slotted into an edge-slit around the rim of the (custom) plastic back.
QuoteAny good car body fixer can take a holey footswitch stamping, weld up the holes, grind flat; then send it out to be fine-finished, stripped, and re-chromed. Same as restoring a fender or bumper on a vintage collectable car. Will cost a LOT.
Fender footswitch? So what part of a fender is the footswitch.
Dares
#6
Thanks a lot guys for all the inspiring replies !
So yes indeed, it's gonna have to be something different to do the job !
:icon_idea:
Paul Marossy
I found a round chrome lid to some kind of kitchen gadget at a thrift store once, it would have made a great tremolo on/off switch but I put a two knob dirt pedal in it. It was about 4" in diameter. The only hard part was fabricating a bottom for it.
