BAZZ FUSS- Can't quite figure out what's wrong
Started by bmsport99, June 09, 2018, 05:34:31 PM
bmsport99
Hey guys, I'm new to the forum and new to the effect pedal game as well.  I have a prototype bazz fuss that has been giving me several issues.  Im following the schematic shown here (with a few changes)
I have added a spdt switch to change between led and 1n914 diodes and a 100k linear pot as a variable collector resistor, and I am also using an mpsa13.  The pedal in bypass has no issues, but when switched on I am left with a very sputtery, short decayed signal that only comes through when lower notes are played.  The volume knob seems to be doing nothing at all.  These are the readings I have taken:
MPSA13 C-8.69V  B-8.47V  E-8.03
LED A-8.7 K-7.2
1n914-8.48 K-7.2
I would appreciate any help with this build as I really want to get this thing working
Welcome!
Is the "ground" on the board connected to battery negative and audio jack commons?
allesz
whichever diode you have switched in at the time will have its Kathode connected to the transistor base. so the K voltage should be the same as the base voltage, surely.
can we see photos of that which you have built, please?
and also welcome.
" I will say no more "
