stupid question about hm2 input buffer
Started by Abyz0u, July 18, 2018, 01:17:21 AM
Abyz0u
i was planning on building the tagboardeffects hm2 ( https://tagboardeffects.blogspot.com/2014/05/boss-hm-2-heavy-metal.html )
but then i realised i dont have any bf jfets+i cant get my hands on any,if i only could find out where the buffer output goes to id put a normal ds-1 style npn buffer OR pop in a normal silicon npn since the circuit looks alot like a silicon npn buffer but i dont know if the biasing resistors need to be changed or which pin of the npn equals which pin of the fet...there is a lot going on that i cant get my head around
so long story short i want to use a normal npn buffer instead of this jfet buffer or socket a si npn instead of the bf245 but i should go about with either of these
antonis
Without a schematic we can tell you nothing..  :icon_wink:
https://www.hobby-hour.com/electronics/s/hm2-heavy-metal.php
(I'm not able for the moment to post an image..)
It might work for Q1, if it's a high gain n-p-n and substitute R8 with a 470K resistor..
Bear in mind Q1 VBE voltage drop at Q2 Base and hence Q2 Emitter + Q1 Source voltage which currently is higher than 4.5V, so you might have to tweak R7 for proper Q1 Emitter voltage..  :icon_wink:
Ice-9
#2
It is just a standard buffer, stick in a npn and it will work fine(Q1).
Most any N-Jfet will work ie, j201, 2n5457, 2sk117 etc and most any NPN Bipolar will play niceley.
www.stanleyfx.co.uk
antonis
@Mick: I'm not sure if simply sticking a n-p-n BJT in place of a n-channel JFET will DO work.. :icon_wink:
Mainly due to pin-out incombatibility (most of BJTs exhibit their Base on middle leg whereas JFETs exibit their Gate on side leg..)
Additionally, a non high beta BJT with 1M Base bias resistor fed from +4.5V leaves not enough Emitter voltage margins for negative cycle undistorted signal..
