Vintage Electro Harmonix Bad Stone Problem
Started by GuitarFreak302, August 27, 2018, 08:02:44 AM
GuitarFreak302
Hello,
I have a vintage Electro Harmonix Bad Stone and it is producing a high pitch whine. When the pedal is bypassed it produces the clean guitar sound but as soon as it is engaged, it gives off the high pitch whine. The pot and selector switch positions do not make a difference, there is always a high pitched whine. I have replaced the electrolytic caps, the lm324n for the LFO and the CD4009 and it did not change anything. Below is the schematic.
Here are some voltages I measured:
IC A:
1)       4.169
2)       4.222
3)       4.142
4)       0.00
5)       4.153
6)       4.197
7)       4.275
8.       7.76
IC B:
1)       4.124
2)       4.120
3)       4.026
4)       0.00
5)       4.110
6)       4.181
7)       4.179
8.       7.76
IC C:
1)       4.179
2)       4.179
3)       4.174
4)       0.00
5)       4.156
6)       4.196
7)       4.239
8.       7.75
IC D:
1)       4.171
2)       4.172
3)       4.161
4)       0.00
5)       4.190
6)       4.181
7)       4.133
8.       7.74
IC F:
1)       3.549
2)       4.136
3)       4.135
4)       7.74
5)       4.107
6)       4.072
7)       4.113
8.       4.073
9)       4.135
10)   4.125
11)   0.00
12)   4.826
13)   3.921
14)   6.472
2n5088:
                E: 4.064
                B: 4.657
                C: 4.066
Thanks,
Ryan
GuitarFreak302
GuitarFreak302
thermionix
Does the noise level change at all if you move it around or to another room?  Just wondering if it's picking up EMI.  If not, I guess audio probe.
Scruffie
I've had this problem once or twice before with vintage EHX pedals and it was a bad op amp oscillating so audio probing is definitely the route to go.
GuitarFreak302
Thanks for the help. It ended up being an opamp.
