need a little help with hells gain
Started by whomeno, August 29, 2018, 04:00:58 PM
whomeno
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
whomeno
Gear as of now
And a lot of pedals
Marcos - Munky
Well, you should have about 9V on pins 1 and 8 of the 7660. If this IC isn't powered correctly, the rest of the circuit won't be powered too. Also, the pins 8 and 1 must have the same voltages; This is where you should start the troubleshooting.
I didn't checked your board. It's just that veroboard layouts just doesn't make any sense to my head.
whomeno
pins 1 and 8 now have 8 volt  pin 8 of 72 has 8 volt
Gear as of now
And a lot of pedals
Slowpoke101
You have a 47K resistor next to D5. It is supposed to be a 47R (yellow. violet, black).
May be part of the problem.
whomeno
yes I caught that one changed it got power where i should
been probing got sound out of the 74 now still now sound at 7660s and 72
Gear as of now
And a lot of pedals
Slowpoke101
The 7660 is not part of the audio circuit. It is meant to generate a negative voltage (split rail) on pin 5. However the 072 should have audio.
Install this missing resistor;
Test again and check all the voltages again. Please let us know your results.
Slowpoke101
whomeno
#8
I did find missed cut . added missed 100k
tlo72
1  0
2  0
3  0
4  0
5  0
6  0
7  0
8  7.69
Also i have no audio on treble - lows and volume pots
Gear as of now
And a lot of pedals
Slowpoke101
OK, progress is good.
You should have -8Volts on pin 4 of the TL072. This is supplied from pin 5 of the 7660 (or similar). You should also have -8Volts on pin 11 of the TL074. The missing voltage is probably caused by a problem with the 7660.
Check the area around the 7660 for shorts, missing links, etc. Check the voltages on the 7660 and let us know your results.
whomeno
072 pin 4 -5.70
7660 pin 5 -5.70
074 pin 11 -5.70
7660
1  7.03
2  3.42
3  0
4  -2.79
5  -5.47
6  2.11
7  2.88
8  6.93
Gear as of now
And a lot of pedals
Slowpoke101
OK. It appears that the 7660 is working but the voltage on pins 1 and 8 is a bit low. Make sure that your battery is supplying 9 Volts or close to it.
Looking closely at the component side of your board some of the resistor values are hard to see but I do think that you do have a few incorrect values installed. Double check your 2K7 and 27K resistors. Also check the 4K7 and 47K resistors. Check them and correct any errors then measure all the voltages on the ICs.
Also check the voltages appearing at either end of the 47R resistor. Let us know your results please. I think that you are very close to success.
whomeno
ok I now have audio coming out of 072 pin 7 going to 1uf cap but not going through cap to output.
any suggestions
Gear as of now
And a lot of pedals
whomeno
#13
ok all resistors are right.
voltage at jack 8.90
074
1  .04
2  0
3  0
4  6.11
5  0
6  0
7  0
8  .94
9  .11
10  .08
11  -4.80
12  0
13  0
14  0
7660
1 5.82
2  2.85
3  3
4  -2.38
5  -4.68
6  1.85
7  1.95
8  5.70
072
1  0
2  0
3  0
4  -4.70
5  0
6  0
7  0
8  5.66
47r  5.60 both ends
Gear as of now
And a lot of pedals
Slowpoke101
The primary battery voltage still seems low but relative to it all the other voltages seem OK.
Your 1uF output capacitor is actually a 0.1uF capacitor. Replace it with the correct value and try again.
If you only have an electrolytic capacitor install it so that the positive lead of the capacitor connects to pin 7 of the TL072.
whomeno
#15
same thing audio on pos side of cap nothing coming through
i used a 1uf  50v pos side to pin 7
Gear as of now
And a lot of pedals
Slowpoke101
Measure the resistance across the 2M2 resistor next to the 1uF capacitor. You may have a short circuit across it. Possible causes would be a stray wire or a wiring error.
whomeno
Gear as of now
And a lot of pedals
Slowpoke101
Set the meter to a lower resistance range. Short the meter's leads together. The meter should show 0 or close to it. Then remeasure the 2M2 resistor. If it still shows 0 or close to it there is a short somewhere.
A picture of your wiring may help diagnose what's going on.
whomeno
still 0 the top of 2m2 gose to out put the bottom gose to volume 1
I don't see any stray wire or anything
Gear as of now
And a lot of pedals
