Turbo Tube Screamer ticking/tremolo issue
Started by Voltzy, September 01, 2018, 11:08:46 PM
thermionix
I don't think it matters what you plug into it, the instability would be in the circuit itself, if that is indeed the problem.
Voltzy
Quote from: thermionix on October 09, 2018, 09:25:01 PM
OK right, looking up some causes of amp motorboating it looks like it is usually caused by a bad capacitor, or some bad decoupling... The only capacitor that is different when in turbo mode is C14 coming off the rotary switch, and I have already tried swapping it out to no avail.
I might try lifting the ground connection of R18 off the board and wire up a separate star ground for it.
Voltzy
OK so I tried starring that ground point which didnt fix the problem and I also soldered a 10uF cap across the power pins of the op-amp which also didn't fix the problem.
I am about ready to give up on this thing, does anyone else have any more suggestions?
