SpinCAD Designer Experimental Release 1023
Started by Digital Larry, September 02, 2018, 01:53:21 AM
Digital Larry
    First new release in over 2 years!
    • Fixed file save when control panel open issue! In older builds if you have a control panel open when you save the file, you can not open that file ever again due to a serialization error.
    • Recently used file lists are limited to 21 entries. Used to be it would just grow and grow and after long enough it would crash because the function to read the list from the registry can't handle it. Plus it was taking too long, and who needs 100 recent files anyway?
    • Fixed some logic in file-open and file-save paths.
    • Added 4-voice chorus block (modulation).
    • Added 1-in 2-out pitch offset (since there is barely enough code space for 2 complete pitch offset blocks) (modulation)
    • Added Room Reverb block (reverb).
    • Added Hall Reverb block (reverb).
    • Added 2 pole SVF adjustable block (filters). This features a notch output in addition to a Q control input and control panel settings for max and minimum Q. My notes say "Q control is flipped".
    • Updated Chirp so that All Pass coefficient can go from -0.98 to 0.98.
Digital Larry
Digital Larry
Bumped up to build 1026, fixed issue running on a clean machine where you cannot save any file.
The recent file folders (unique for SpinCAD Patch, SpinCAD bank, hex, spn and spj (Spin IDE Project)) default to the execution location of the SpinCAD jar file and then once you navigate elsewhere they are saved.
http://holycityaudio.com/forum/index.php
Digital Larry
potul
Digital Larry
Should, please let me know if they don't.  It kinda depends on how far back you want to go but I've tried it with files from the previous release.  Our QA team is a little lazy sometimes (cough).
Digital Larry
potul
Ok, I'll give it a try tonight... For some reason I can't get to your forum from work... looks like your site is in the proxy black list... Weird.
potul
So far I have been able to open all my previous files with the new release. Great!
And for some reason your site seems to be removed from the black list. I can reach it from the office now.
