help with oscilloscope model 34
Started by whomeno, October 11, 2018, 11:24:12 AM
whomeno
just tried with old meter same results
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
whomeno
if i probe the 400v rail I get .43
If i probe any test points I get 0
Hooked up meter like post 170
there is power there= 1.034 set on auto
Gear as of now
And a lot of pedals
whomeno
if there was some thing wrong with probe
how can i get the 400v rail to measure?
Gear as of now
And a lot of pedals
Quoteprobe is working can test C33 a-b -c-d
Quotejust tried with old meter same results
It's good you checked those because it makes the numbers more believable.
So power down the unit and remove the mains plug.
Wait about 1 min or so.
I'm not sure if you actually got a resistance measurement for V8 pin 5 to ground and V8 pin 4 to ground.
A good measurement there will help at this stage.  Perhaps V7 pin 6 to ground and V7 pin 1 to ground.
For sake of removing ambiguity pull V8 and V7 for the test.
QuoteHooked up meter like post 170
I didn't get what you were saying here.
Quoteif there was some thing wrong with probe
That's the point of measuring the 400V line.
The probe measurement looks good.
It's not only close it is measuring quite accurately.
whomeno
V8 pin 4 OL
pin 5  = 1.8
V7
pin1 =all over the place
pin 6 =.1
Gear as of now
And a lot of pedals
QuoteV8 pin 4 OL
pin 5  = 1.8
V7
pin 6 =.1
Were they ohms, k ohms or M ohms?  (makes a big difference)
whomeno
back when we tested for the 550 to see if the transformer was bad
If you are confident about taking a measurement, the voltage across R57 would be a good indicator.
- Turn off the unit.
- Wait about 1min
- Set the meter to 1000V DC scale.
- Make sure the meter leads are in the COM and V terminals
- Wire the meter to R57 (the side that goes to the Focus pot) and ground
- Power up the unit and take the measurement.
   (- You expect about 550V)
- Turn off the unit
- Wait about 1min
Be careful!
Gear as of now
And a lot of pedals
whomeno
Gear as of now
And a lot of pedals
Quoteback when we tested for the 550 to see if the transformer was bad
OK.   Well if you were getting 1V with just the meter it is 1V but with the 1.5kV probe
you will see 1V / 1000 = 0.001 kV  so it might show up as 0.000 or 0.001.
Quotesorry k ohms
Hmm, well those measurements don't look promising.
Another check would be to measure the resistance *between* V8 pin 4 and V8 pin 5.
whomeno
v8
pin 4 to pin 5 =OL
v7
pin 1 to pin 6 = all over the place
Gear as of now
And a lot of pedals
thermionix
Quote from: Rob Strand on October 19, 2018, 12:57:24 AM
QuoteI haven't read through the whole thread, but it would be pretty sucky to go through all this trouble and find out the CRT is dead.  Do you at least see the heater lighting up?  Assuming it's not obscured by the cathode, socket, yoke or something.
I think he mentioned it was lighting up very early in the thread.  Maybe even in his other thread where be bought the equipment. see post #3 and post# 10
My bad.  Ignore me.  Carry on.
Quotev8
pin 4 to pin 5 =OL
That implies the heater winding has gone.
Your previous result that pin 4 is OL would imply that it is the winding going to pin 4.
When the unit is running can you see the heater of V8 operating?
From what I remember it was hard to see those heaters working.
Quotev7
That's not good.  It agrees with your previous measurement that pin 1 to ground is all over the place.
That's implying the winding from pin 1 to ground has failed.
We are getting 430V DC but it's only half-wave rectified and is only utilizing one side of the winding.
whomeno
#213
ok, so how much would it cost to replace.
More then it is worth right
How would I know what to replace it with even
Gear as of now
And a lot of pedals
whomeno
Gear as of now
And a lot of pedals
whomeno
I got a quick question about something else.
I am going to build a tonepad mctube with a 12ax7.
I think you answered this before but can't find it
would this transformer work
https://www.tubesandmore.com/products/transformer-power-125-v-15-ma
Gear as of now
And a lot of pedals
Quoteok, so how much would it cost to replace.
My gut feeling is that.
However, it would need some research. You never know what you find.
Sometimes you find people selling second hand transformers from the same model oscilloscope.
The problem with these is they could work today and fail tomorrow.  Pot luck but better than nothing
Another pot luck solution is to get another unit cheap and use it for parts.   No guarantee the transformer in that unit is any good either.
If you had to get one made I suspect it would cost a lot.
Another option would be to adapt an existing transformer.  You would probably have to redesign
some of the power supply to do that.
You could turn things around and see that unit for parts.  One issue is you don't know the CRT is good.
QuoteI got a quick question about something else.
It won't work directly.
This come-up in another thread within the last month or so.
(To me) the issue is the transformer voltage is going to produce a high-voltage DC rail which exceeds
the 150V/160V rating on the caps.  You will need to add a dropping resistor (with appropriate power and voltage ratings), possibly even a voltage divider, on the high voltage winding.
Alternatively, you could use higher voltage caps but then all the voltages are out and you might have to tweak the circuit a bit.   Also it's not quite the same thing as it was before.
whomeno
That was my thinking try and sell it for parts.
Would i need one if i try to build an amp?
Gear as of now
And a lot of pedals
whomeno
Gear as of now
And a lot of pedals
