DIY Fuzz Pedal - can't understand the electric cirruite
Started by ariklahav, October 13, 2018, 02:26:01 PM
ariklahav
Hello
I am new in DY business
I tried to build kit of Fuzz-Pedal- With-1590B
I was very disappointed to find that there are no Detailed circuit English schemes
I found it difficult to understand the connections of the switch 08-7822
Which is supposed to have 6 pins and the set has a 9-pin switch
And where are the power inputs
I will appreciate any help
aron
DIY Bass
The pictures look as if there is a folded piece of paper in them.  I would assume that has instructions.  Did that instruction sheet come with your kit?  It would be helpful to post a copy here if you have it.  The switch you have will do the same job as the 6 pin switch, you only use 6 of the 9 pins.  Do you have a multimeter?  If you do then that makes it easy to work out which pins to use.
ariklahav
thanks you helped me It works but I have noises and no fuzz sound/ any ideas?
