Troubleshooting IC BMP Build
Started by wimacfee55, October 30, 2018, 07:52:22 PM
wimacfee55
Long Time Lurker, first time poster. I hit a wall troubleshooting a IC BMP build and I followed the debugging guide post as close as possible:
Also, thanks for all the help that's on this forum. It's one of the best things I read each day.
1.Name of the project: EHX IC Big Muff V5 '78 as done by Tagboardeffects
2.Links to the source of the project web site with the schematic or project, layout and wiring diagram: https://tagboardeffects.blogspot.com/2013/12/ehx-ic-big-muff-v5-78.html?showComment=1540813326822#c282828169989013548 with a similar circuit that I've used for understanding here (the 1978 OpAmp ciruit) http://guitarpedalbuilders.blogspot.com/2012/06/1977-1978-big-muff.html. Quick note, for the Veroboard, I denote the upper right hand corner spot as A1, and the bottom right hand corner as R20, the letters are the Y axis, the numbers the X axis.
3.Some candid admissions about how closely you followed the suggested layout, if any. If you just perfboarded it, say that, and if you can, include a picture of the board: I have used a vero strip board, multiple photos included for inspections for shorts, bad solder joints, etc.
4.Any parts substitutions or modifications you made to the original. I followed the suggested chips and diodes closely and matched the pinouts: minor substitutions for caps where it was near enough. For example, I subbed a 1.2K resistor for a 1K resistor in a spot. All electrolytic caps were matched to the value requested.
5.Whether or not it's a positive ground circuit like a PNP fuzz or a Rangemaster that has been hacked to work with negative ground: not the case, negative ground.
6.What it does and does not do how it works: Works in bypass with no issues. When the effect is engaged, the typical sound is as if it is still in bypass, then it cycles through a few different sounds, from a faint and distant fuzz, to the expected roar. Sound is making it through, just intermittently. I verified the jumpers between strips are current and the cuts in the stripboard are correct by using a continuity meter. I verified component placement and made only minimal swaps. I used an audio probe to trace it from the input, and while I get a strong signal at pin 1 of the JRC 4558, I get a faint sound at pins 5 and 7 of the chip before it goes off to the sustain pot. I also triple checked for shorts across the Veroboard to attempt to catch anything there.
Voltage list: Power supply: 11.6V (Boss 9V wall wart)
JRC4558 Pin 1: 5.65V
Pin 2: 5.67
Pin 3: 5.62
Pin 4: 0.1mV,
Pin 5: 1.14V,
Pin 6: 1.41V,
Pin 7: 1.48V,
Pin 8: 11.2V
UA741CP Pin 1: 3.5mV,
Pin 2: 6.1V,
Pin 3: 5.85V,
Pin 4: 0.1mV,
Pin 5: 3.5mV,
Pin 6: 6.4V,
Pin 7: 11.2V,
Pin 8: 0.04 to 0.08V varying as I measured it over 2 minutes
> JRC4558
> Pin 1: 5.65V
> Pin 5: 1.14V
These two should be essentially the same. Something is leaking here.
antonis
#2
I pressume drops (about 20μA each one) are protons, due to their leakage direction..  :icon_wink:
wimacfee55
Thank you PRR! This is a step in the right direction. I measured the voltages leading up to the 47K resistor and the 4.7nF cap.
One quick note about a difference between the veroboard and the circuit, the veroboard has no direct link to connect Pin 5 and Pin 6.
Perhaps the leakage is from that 10nF cap going to ground? That's the only other component on that strip (G11 to G20)
wimacfee55 - seeing as no-one else has yet, welcome to the forum.
the drawing convention used on your dia suggests a "connection" is made between lines only where a dot appears. you don't want any connection between pin 5 and pin 6.
[edit: ] a closer look at your board shows what appears to be a shorting link between pins 5 and 6. snip it out, remeasure yr voltages.
" I will say no more "
wimacfee55
Thank you duck_arse, it's a pleasure to be here!
Yes, I originally made that connection and snipped it, the resolution on the photo doesn't quite show it, but theres ~3mm between the snipped ends. The voltages I have listed are still what I'm seeing. When I get back from work today I'll desolder those pieces and replace the 10nF cap that's there on the strip with pin 5
wimacfee55
That 10nF cap to ground was the culprit! I replaced it, removed the snipped link and it roared to life. Thank you so much for the help everyone!
wimacfee55
This Pedal is back to cause me more grief, I'm getting almost no signal at the output.
I've traced it with an audio probe, and I lose the signal after R10 (8k2, after the second leg of the sustain pot). At leg 3 of the sustain pot, I don't have much of a distorted signal after the JRC4558, the signal is quieter than the input of the JRC4558 at pin 2.
I've replaced the greenie caps that caused the issue before, and I remeasured the Pin Voltages:
Power Voltage: 11.4V
JRC4558 Pin 1: 5.54V, Pin 2: 5.54V, Pin 3: 5.48V, Pin 4: 0V, Pin 5: 5.25V, Pin 6: 5.30V, Pin 7: 5.4V but varies with time, Pin 8: 11V
UA741: Pin 1: 0, Pin 2: 1.98V, Pin 3: 0.1V, Pin 4: 0V, Pin 5: 0V, Pin 6:3.34V, Pin 7:11V, Pin 8: 0.1V
As always, thank you for the help. If this winds up being a ghost in the machine again, I'm just getting the PedalPCB board for it...
wimacfee55
Figured it out! Cold solder joint on pin 8 on the UA741. Thank goodness I posted the voltages here before, my records are not so good in the old marble journal
not to rain on your parade or anything, but pin 8 on the 741 is not connected to anything in that circuit. unless you've modded it [?] and then, still, probably not a thing. are you sure of your part/pin references?
wimacfee55
Now that you mention it, you're right about pin 8. I didn't mod it from the tagboard layout, and I did re-solder each of the UA741 socket pins as well as each component in the audio probe trace. I'm going to add re-soldering each joint as a troubleshooting step for next time and not trust my eyes for cold solder joints.
