I need help debuggin a Big Muff Pi
Started by DeusM, January 03, 2019, 10:53:32 AM
DeusM
Hey guys. I made a BMP and it doesn't work. It's the second time. I probed it with an audio probe and I can hear sound from the beginning of the circuit but when the guitar is plugged the volume is too low. Basically I respected the circuit. I added a prescense control in R19 like described in AMZ. I added a switch to activate it or jump staring to earth at that point to remove mid scoop. Triple checked connections twice. Here are the measurements:
Q1
C = 8.75
B = 1.45
E = 1.13
Q2
C= 3.95
B= 0.65
E= 0.05
Q3
C = 4.29
B = 0.60
E = 0.03
Q4
C=7.61
B= 8.2
E= 7.59
D1
A = 3.64
K = 3.96
D2
A = 3.96
K = 3.64
D3
A = 4.29
K = 4.00
D4
A = 4.00
K = 4.29
D5
A = 0
K = 9.09
Schematic
I used PN222A in Q1 Q3 Q4 and MP2A18 in Q3
I took some pictures of the pcb but they look bad.
I hope you can give me a hand guys. Thanks!
It's not the amps that kills you. It's the "mojo"
You've double-triple checked the connections.  Have you rechecked the component values?  At least Q4 looks misbiased.  (I don't really know offhand what the voltages should be though).
DeusM
Quote from: EBK on January 03, 2019, 11:24:17 AM
Not of all the components. I was very careful when I placed them but I'm going to doble check them again.
When I probed from Colector of Q4 it sounded loud and clear but I'll check the emisor resistance.
DeusM
Ok. So I had one resistor wrong. Now there is sound but not distortion. I'll keep checking resistors,
DeusM
Rechecked componen values. They seem fine. Could it be that I still dindt put the LED? Can it afffect the circuit? I'm going to check the new values in the trantistors
DeusM
Now it reads:
Q1
C = 8.75
B = 1.45
E = 1.32
Q2
C= 3.95
B= 0.65
E= 0.05
Q3
C = 4.29
B = 0.60
E = 0.03
Q4
C= 5.96
B= 1.57
E= 1.09
Now I'm looking at Q1.  That collector voltage looks high to me (again, without knowing what it should be in this circuit).
DeusM
Working! There was a pad lifted at Q1 emiter. Is was imposible to see but there was no continuity. Thanks for your help EBK! Your always there when I need it. I'm going to rock now.
