I've designed a Filter Pedal for Bass
Started by FUZZZZzzzz, January 09, 2019, 02:01:26 PM
FUZZZZzzzz
Hi guys!
It's been a while since I've posted. I just finished a new pedal that I've been working on and decided to share it with you guys. It's a very simple design with only a few parts. If you want to change the sound of the filter you can change the diode and value of the 4,7 nf cap. I prefer both the 2,2 nf and 4,7 nf on a switch. The 1n4148 give the most clean result. The 10k pot tames the filter intensity. You can abandon it completely if you like mayhem. I can create synth like tones (play with the 4,7 nf cap) and even some funky stuff.
The enclosure is tiny. Was a real adventure to make it fit. Enjoy!
"If I could make noise with anything, I was going to"
brilliant, great simple design..nice work man, sounds great... 8)
FUZZZZzzzz
thanks! i'm indeed very happy with it. it's also very quiet when you're not playing.
It looks like a synced oscillator circuit. If I was feeling pedantic, I'd have to argue with the description of the circuit as a "filter", but luckily I'm not feeling pedantic so I can just let it go and sit over here and do some breathing exercises...breathe....breathe...breathe...;)
Extremely cool design.  I was playing around EQ'ing the output and there's a lot of sounds in there.
Where did you get the idea for diode and 4n7?   It's not a normal thing to do.
I heard this track a few months back (Synthy bass comes in a 0:30).   I wonder if your circuit can help get that sound.
https://www.youtube.com/watch?v=boLGFfnCZDg
FUZZZZzzzz
#6
Quote from: ElectricDruid on January 14, 2019, 05:59:35 PM
Sorry, but if I had called her Barbara it would be even more misleading ;)
FUZZZZzzzz
Quote from: Rob Strand on January 14, 2019, 06:13:38 PM
Feel free to design an amazing EQ section for it. ;)
The idea for the diode and 4n7 (2n2 is even weirder) is just based on trial and error. I just like to play around and try different stuff. Most of them is textbook, but the other half is experimental just like that diode and cap.
I will listen to it later and tell you.
Does it have to be LM567, or I can use LMC567?
FUZZZZzzzz
Suppose so. Ive used ka567 / ne567 and lm567 before. Please let me know if it works
Marcos - Munky
Firstly I thought this was something similar to Hemmo's Noise 567:
But yours is different. For example, your frequency cap is between pins 2 and 3, while Hemmo's between pin 6 and ground. A suggestion to try from Hemmo's one is to get the output from pin 2 instead of pin 1.
Also, Tim Escobedo have a modified version of Hemmo's circuit called Thing Modulator, where he stated a LMC567 would reduce oscillation bleeds when the effect is bypassed. So an LMC567 probably will works great on this one.
Could you draw a schematic of yours? I know it's a simple design, but my mind can't understand vero layouts.
Marcos - Munky
I compared the schematic to the layout and it seems correct. I'll draw a layout for a 1590A later.
FUZZZZzzzz
Ive build the ring modulator years ago. Its very noise. This design is very quiet even with normal 567 ics like lm567 ne567 ka567. The sound is also nothing like the thing modulator.
Thanks for the schematic!!!
Marcos - Munky
Well, didn't made a 1590A layout, but the guys at Efffects Layouts made one:
http://effectslayouts.blogspot.com/2019/01/bass-filter-pedal.html
It should be an easy fit in a 1590A.
bluesdevil
Very cool and easy build! I have that chip stashed away somewhere and this will be a good excuse to dig it out.
Thanks for sharing.
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
FUZZZZzzzz
Quote from: Marcos - Munky on January 17, 2019, 03:03:30 PM
I see they've added a 100 uf cap in the power section. Has anyone, besides me, build this pedal?
Quote from: FUZZZZzzzz on January 18, 2019, 04:17:12 AM
No I didn't, but I will :)
DDD
#18
Surprisingly simple schematic based on the not so simple theory.
It's a real masterpiece!
Thanks for sharing!
*** By the by I'm sure that serial BLUE LED instead of the 7806 will do the same work perfectly, giving a bright indicator light as a bonus.
Too old to rock'n'roll, too young to die
rutabaga bob
Nice, simple, easy circuit - but mine's not working.  Used an audio probe...there is no signal at either pin 2 or pin5.  Triple-checked against the schematic and all looks right.  Possible toasted chip?
"I can't resist a filter" - Kipper
