Duncan Shape Shifter Tremolo - Replacing a 4 terminal pot with 3 terminal pot
Started by usgmp, January 22, 2019, 12:50:05 PM
usgmp
Any pointers on this?  Assuming the 4 terminal one is center tapped.  Doesnt seem to use the center tap when i look at the circuit board for anything on the depth control.  Anyone know which lug is the center tap?  Or is there a way to know with measure resistance? could I omit it entirely and just use 3 lug?
Haven't run in to a pedal that uses a 4 lug center tapped pot before.
thermionix
Pots can be tapped in places other than center.  You can figure it out with your ohmmeter if you take it out of the circuit.  I think a tapped pot can be simulated with a standard pot and added resistors, but it gets complicated.
Some 4 terminal pots just have a fourth connection for grounding the case, in which case (ahem!) it can often be ignored. Again, the best way would be to remove the pot and measure it.
HTH,
Tom
