The Please Steal My Idea Thread
Started by EBK, February 20, 2019, 04:36:36 PM
Quote from: duck_arse on February 27, 2019, 08:27:19 AM
I was going to do some of these - but I couldn't find the parts.
I've got some spare air parts I can send you?  By airmail of course...
Joncaster
I want to do a Big Muff in dead bug style and call it Bug Muff.
Music is Eternity: stretched like the sky over the landscape of our lives.
"It's better to be looking at it, than looking for it."
My Band:
http://www.coldwatermorning.bandcamp.com
I would like to see a cavity resonator drum.
Using the usual dimensions of a drum, this would be an oscillator in the VHF or UHF frequency band.  You would have an envelope detector for each resonant frequency (a drum has resonances that are Bessel functions of the zeroth order) and a divider that would bring the frequencies down from the order of a hundred MHz to the audio band.  The resultant frequencies would be multiplied by the envelope and you would recover a drum sound, all without the need for a microphone, avoiding the direct feed of ambient sound (except as it affects the drum skin).  The drum would have a conductive layer on the sides and conductive film on the skin.
To get a snare drum, the snare could be laid beside a rigid conductor and charged to a high voltage.  The movement of the snare would induce a voltage based on V dC/dt.  In this case, the varying capacitance is what induces the voltage.
If anyone feels the insane need to build something like my Chia Pedal, I think a MossFET distortion pedal would be pretty cool.   :icon_cool:
Probably easier to build and maintain too.
Quote from: EBK on March 01, 2019, 07:02:00 AM
boom-tish, as BB would say.
I heard say that Keef refuses to use mosfet based pedals.
" I will say no more "
patrick398
I always wanted to find some way of fusing the sound of my guitar with the sound of a dial up modem, think it would sound pretty far out but i lack the computer know how
Kevin Mitchell
Quote from: patrick398 on March 01, 2019, 09:29:57 AM
So a type of sample/hold that makes your ears bleed?
Call it The Beat Box. Everyone will think it's broken and just pound the hell out of it. Misleading or right on the money?  :icon_lol:
Kevin Mitchell
Wait a minute. What about a sample/hold where the phase threshold can be dialed via foot controller? Is this a thing yet?
marcelomd
Quote from: EBK on March 01, 2019, 11:14:15 AM
Nah. Call it Purple Hayes!
Only the chosen ones will understand! I like it!
You can get photosensitized circuit boards that you expose with the pattern you want.  Why not enclosures?  You take it to your dark room, set up the etch pattern you want on a projector, expose the box and drop it in the etch chemicals.  No toner, no transfer, no repurposed steam iron, just an enclosure that you drop in acid when you are satisfied with the image.  Someone on this site with photography equipment should try this.
DaveLT
Quote from: amptramp on March 01, 2019, 06:03:33 PM
Photography equipment... in the 80s perhaps
Quote from: DaveLT on March 01, 2019, 07:55:59 PM
Photography equipment is a flea market / antique store / estate sale item now.  Or you could use a projection display showing a jpeg of the image you want to see on the enclosure.
You could perhaps print an image onto clear film and use that as a photomask as well.  I think I've seen silk screening setups created like this (but it was many years ago, so the details are hazy).
Instead of using etching to decorate enclosures, there are miniature sandblasting guns used to etch glass.  Some enterprising individual will start using this to manufacture enclosures using rubber or vinyl templates.  Need more etch depth?  Just press the trigger a little longer.  Need bas relief?  These things do that.
Quote from: marcelomd on March 01, 2019, 11:34:36 AM
I'm bored with these gags.
anotherjim
The Pentacle of Infinity.
It's x5 PT2399's arranged at the 5 points of a pentagon star. Reading clockwise, each delay inputs the angle from the left and outputs to the right. One delay is chosen for signal input mix, and another (could be the same one) for output mix. The audio will travel through all 5 in turn and back again endlessly. Arrange path in anticlockwise direction for Death Metal.
I'd like to see a pedal with lots of knobs and switches, each labeled, "I am Groot".
stallik
I shoved most of a pro darkroom into my attic 20 years ago. It's still there and, the older I get, the heavier it seems to be so it'll stay there. My wife says that if I put anything else up there, the house will be so top heavy it'll turn over in a light wind.
There is electric up there and it's pretty dark.. Might be worth a play
highwater
#99
Quote from: EBK on March 01, 2019, 09:28:29 PM
You'd probably *have* to do it that way... photoresist (like this) requires UV light, which would require an enlarger lens FAR more expensive than, say, a laser-etching setup.
(edit) It's probably also easier that way... enclosures are neither big-enough nor small-enough to be worth mucking-around with an enlarger, even if any old lens would do.
I'm not sure if that photoresist is burly enough for enclosures, but it's certainly worth a try.
"I had an unfortunate combination of a very high-end medium-size system, with a "low price" phono preamp (external; this was the decade when phono was obsolete)."
- PRR
