Seppuku kompakt kassette/broken tape delay style pedals?
Started by jimladladlooklike, March 04, 2019, 07:29:13 AM
> The envelope detector/generator
Following an arbitrary envelope is different than generating a specified envelope.
The plan you show does the same thing every time (until you turn knobs). It is not going to follow the volume of a player in real time.
jimladladlooklike
Okay, so by that you mean the attack/release is simply set by the two pots and is not sensitive to how hard a player plays?
input to your shown circuit is labelled "gate in". this implies on/off, nothing in between. whatever you set release and attack as is what outputs each time the circuit is gated.
you can strip an envelope generator/precision rectifier [search term] circuit block from any compressor or autowah or attack delay or noise gate ...... depends what you want it to control.
" I will say no more "
jimladladlooklike
Okay so I've made an simplified version of the Mutron III envelope generator:
Is this worth a go on the bread board?
