26A7, 30V tube amp, 1/2W maybe?
Started by printer2, March 19, 2019, 11:38:02 PM
printer2
I have a 16A7 tube which is a double pentode that has a 26V heater voltage and runs at 26V plate voltage for a rated 1/2W. I figure if using a 24V transformer and rectifying it the supply should be a little above 30V, finger safe for those hesitant about high voltage. I thought a 12AU7 would be linear enough at this voltage and a pair should be able to drive the 26A7 to full output using a 70V line transformer as the OT. Part values will probably change, just stuck in some to make the schematic look right. Three versions up for consideration and a critical eye.
Fred
Try all three; but my 2 cents is on the cathodyne working best *WHEN* you do it right.
120+120:12V power transformer is very nearly 2500:8 impedance ratio, is at least 2500 impedance at 50/60Hz so will have some bass, and PP 26A7's 40V audio on a 240V winding should be low THD. Depends whether small power iron is cheaper than small 70V speaker iron in your life. (Outside the US area, 70V line iron is rare.)
printer2
Thank's PRR, I just did a quick cut and paste and was not paying attention. I had a fixed bias Mosfet/fet in place at first and an extra gain stage but though it might be unnecessary for a sub-watt amp. I am unsure of a tone control also, well one can't hurt. I'll know more once I breadboard it.
Fred
printer2
Going to take a page out of the hifi people's book as far as a chassis. Just a sheet of galvanized steel and some spruce strapping. Will mount everything off the steel and if needed lay some aluminum tape over the wood sides and back.
Fred
