Tonepad Small Clone Debug + CD4047 test (post 2 by slacker)
Started by strungout, June 02, 2019, 12:06:13 AM
Fender3D
The clone theory schematic I got shows pin 4 connected to bias partitor...
Kevin Mitchell
Quote from: Fender3D on February 03, 2022, 12:30:26 PM
Yeah you're right, I see it. Didn't consider that the Tonepad version may have come before the EH Reissue and it would be slightly different.
If you found the same schematic from the same site I had, you'd probably also notice a wild profile photo of PinkJim right under it. I can't stop laughing.
AdrianM55
Quote from: Fender3D on February 02, 2022, 02:20:29 PM
Quote from: AdrianM55 on February 01, 2022, 04:08:03 PM
My one is the clone theory reissue any ideas?
And the issue is?
BTW
3007 pin 4 should be somewhat higher than 0V
4047's pins 10 and 11 should be similar (both fluctuating in your case).
check with o-scope or freq. meter if you have clock there...
I don't seem to get modulation at all but can hear oscillation. And it's quiet on 3rd mode.
Fender3D
You have 2 "oscillations" here, one is low frequency, you got it on depth control wiper, it comes from IC2 (LFO), the other is high frequency and you got it on 4047's pins 10 and 11 (clock).
did you check what I suggested before?
