Help With Op-Amps
Started by TSMartin, June 17, 2019, 11:31:57 PM
TSMartin
I am still fairly new to all of this, so bear with me.
Whenever I use an op-amp for anything, I lose a lot of sustain, and my notes fade out quickly, resulting in a gross, distorted, "plucky" sound. I've used TL082, TL074CN, OPA2134PA, RC4558P, LM833N. They all seem to give me the same issues. I connect them to 4.5V Vcc+. In general, I've been using them to boost a signal before an overdrive clipping section, or after a clipping section, like you would see in an OCD style overdrive.
I'm hoping there is a fairly common cause to this that someone can help me with quickly. If it could be a number of problems, a nudge in the right direction would be great. Thanks!
EDIT: Here's one of the schematics I was trying to follow: https://www.google.com/search?q=ocd+schematic&rlz=1C5CHFA_enUS751US751&tbm=isch&source=iu&ictx=1&fir=si_6qbR0kHNtgM%253A%252COUlgUiDhTjY2zM%252C_&vet=1&usg=AI4_-kTKcIxloVF_IxLpAyxB4FUOkHsoFw&sa=X&ved=2ahUKEwikvsaUnfPiAhUF5awKHURJD4EQ9QEwAHoECAYQBA#imgrc=si_6qbR0kHNtgM:
Any schematic (diagram) of your builds should be helpful..
GibsonGM
Hi TS, Antonis is correct - a schematic of something you have built and which gives you trouble would help up pin-point what's wrong.   Generally, the error is a build error, or a problem with our design if we made it ourselves.  Happens to all of us!  :)
The symptoms you describe suggest that maybe some clarification on how opamps work with AC signals could be in order, but we'll know more after we can look at a schematic.
Welcome to the forum!  :)
Quote from: GibsonGM on June 18, 2019, 06:06:21 AM
You could duplicate the above on my behalf, couldn't you Sir..???  :icon_redface:
ohhh, I've seen the circuit! and I'll add a welcome.
on the left is the "Power section". in that section you'll see a black down-poining triagle and an open down-pointer. all black triagles (ground, earth, common, 0V) to the right of the power section connect together with the one in power. all the open triangles (V/2, bias, Vb, +4V5) connect together with the open triangle in the power. this provides all the grounds and biases around the circuit. [ignore the name "op-amp ground" - think of it as bias instead, worry about relative nomenclature later.]
all except one - the IC supply connections are not shown on that dia, and they are verrrr important! connect pin 4 of your op-amp to ground, the solid black, and pin 8 of the oppie to the 9V line.
and also - two more grounds are missing, one for the input jack sleeve, and one for the output jack sleeve. all your grounds connect together.
" I will say no more "
Wot Duck sed. Sounds like you're having trouble with the "bipolar supply" requirement of the op-amps. Once you get that sorted, you'll be fine.
Hmmm...
I'll bet you guys a bottle of cider (especially for Stephen) in case of problem doesn't concern output current limiting resistors..  :icon_wink:
GibsonGM
Quote from: antonis on June 18, 2019, 06:22:51 AM
From Antonis and myself, Welcome! :)
Like that?
Rixen
Welcome, when you say you connect them to +4.5V Vcc, do you mean that is from where you supply power to the op-amp ? The +4.5V is a ground reference point and the op-amp should be powered from the +9 and 0 V rails. Apologies if this is how you have it connected, but I've seen (and done) all manner of incorrect stuff with op-amps
GibsonGM
Quote from: Rixen on June 18, 2019, 09:27:05 PM
I think that is why we need a schematic...
Quote from: GibsonGM on June 19, 2019, 05:08:12 AM
The added link in the edited OP is a Google search which eventually leads you to this:
Quote from: antonis on June 18, 2019, 12:40:32 PM
What's your thinking, there, Antonis?
I was thinking that if the OP was having trouble with many different op-amp circuits, then it was probably power related (get that wrong, and nothing works). But it's also true many circuits have a series resistor on the output.
wot hizz druidness said. how'zit work antonis?
but I'll still have the cider, thanks.
Just a wrong (low) value resistor before clipping section should cause the issue, Tom..
OK Stephen, no cider for you anymore... :icon_mrgreen:
