Amp help pls
Started by ReeceAblaze, August 21, 2019, 07:19:55 PM
ReeceAblaze
Hello everyone I just got a second hand AC30. The one problem is that the power and standby LEDs have sunken into the case. How safe/easy would it be to open it and put them back in their slots?
Fuzz is all you need!
How easy is it? Very.
How safe is it? How much experience to you have being inside tube amps?
Congrats on getting a killer amp secondhand though 8)
ReeceAblaze
Quote from: vigilante397 on August 21, 2019, 07:42:24 PM
Is it as easy as pushing them into where they came from?
And I have no experience in tube amps. But someone has told me the LEDs are close to the power section. I wanna fix the issue because I can't see either light and its bugging me but I dont wanna die or get hurt over it lol
How safe is it? .....
.... a killer amp .....
perhaps could be worded better.
" I will say no more "
Step 1: Turn off the amp
Step 2: Unplug the amp
Step 3: Wait for a while (have a drink, watch some TV, etc.) for the caps to discharge
Step 4: If you own a multimeter check the filter caps for voltage (just to be safe)
Step 5: Take the screws off the back panel
Because of how they mount the chassis vertically you should be able to see the entire circuit at this point, so you should be able to see the LEDs. The leads may be bent so you may have to bend them back to stay in place with needle-nose pliers or similar.
Step 6: Take pictures ;D
willienillie
Quote from: vigilante397 on August 22, 2019, 11:52:08 AM
Does this version have bleeder (voltage divider) resistors?  I only have schematics for old AC30s.  You can use a jumper wire from a preamp plate resistor to ground, flip the standby switch on, safe in a minute or so.
mth5044
Never assume the caps are discharged. Read up on tube amp safety. Sunken LEDs would be a real shitty reason to get shocked or electrocuted. If you don't feel comfortable, get someone else to do it.
ReeceAblaze
Quote from: mth5044 on August 23, 2019, 01:04:23 AM
I called a guy last night that does electrical repairs. He will be round to look at it today at some point
iainpunk
yellow rubber cleaning gloves, thats all im going to say
cheers
