KOT Overdrive diode swap question ??
Started by HOTTUBES, September 05, 2019, 09:59:44 PM
HOTTUBES
In the middle of a KOT overdrive build and it calls for the MA856 diode . I don't have any of those on hand , but after measuring many of the diodes i have on hand i came across some 1N4739A or 1N4742 diodes that measure around  .702 FV .
So the question is , will either of these diodes work as clipper replacements in this application  ?
Thank for any help !
MA856 appears to be a very ordinary Silicon diode, except at currents much larger than we find in a pedal.
I suspect the radio side of the factory had an overstock of MA856 and the pedal side of the factory said "Hey! Cheap diodes!" and snagged it.
