Parallel Tremolo /Ring Mod Chopper Brainstorming
Started by Mr. Lime, October 04, 2019, 01:20:31 PM
Mr. Lime
Quote from: Kipper4 on October 23, 2019, 03:08:14 PM
As for the ldr it depends on what you want the last stage to do. Boost, unity.
Maybe experiment from a 5k bright up.
Might be worth experimenting with a variable CLR on the led too. Series 1k-10k variable-rail.
GL55xx series may vary quite a bit for ldr. Some matching may be required.
Might be worth popping an nsl32 vactrol too and again play with clr.
Does the tapflo 3 have a 50% duty cycle and 100%
Sorry for all the questions
Thanks Kipper!
It all depends on the bandpass divider. Generally I'd like to have unity gain as the last stage's volume control is just a trim.
I hope to archive some kind of phasing sound through the harmonic split into highpass and bandpass so that the different waveshapes from the LFO are better pronounced than with a simple tremolo circuit.
I attached the LFO section as well.
There are controls for LED brightness included as well as phase reversing and a CV input either for the lowpass tremolo or the wah shifting.
Vactrols are so damn expensive that I might not even want to mess with them but I think I have two nsl32 laying around somewhere..  :icon_mrgreen:
Thanks for help
