Cleaning PCB
Started by spoontex, November 16, 2019, 08:25:29 AM
spoontex
Hello,
wich is the best way to clean the PCB, after soldering with flux?
I've tried isopropilic alcohol, but sometimes it is worse...
How do you do it?
thanks.
I find that, in addition to isopropanol on a toothbrush, a bit of ethanol in a glass makes the process more enjoyable.
The toothbrush does leave a bit of sticky film behind, so the process is not perfect, but it seems to become less sticky after sitting for a bit.
There are flux removers available, but I have not tried them.
bool
Quote from: EBK on November 16, 2019, 08:38:24 AM
Don't use denatured!
spoontex
I will be happy to se your methods.
Hardened flux i just pop off with a stainless steel dental pick. Any remaining dust gets brushed away with a very short bristled artist brush, compressed air if the compressors running.
dave
This guy is a shining example to us all about board cleaning:
Ice-9
Quote from: amptramp on November 30, 2019, 08:49:42 AM
I have a power jet washer for this purpose but when that is not enough I use a sand blaster.
www.stanleyfx.co.uk
