What did I build? Help me identify
Started by cab42, November 26, 2019, 05:24:05 PM
cab42
I was going through my box of abandoned circuits in order to find a Hogs Foot I once built.
However, the board I thought was the Hogs Foot, was something Else, but I don't know what.
I drew a schematic from the vero I built it on. It looks familiar but I have searched and searched and haven't found anything
It looks like some kind of booster or od/fuzz. The first pot meter was actually a 100k lin with a 32k resistor across so I guess i did not have the right value. The volume  pot in the end is a qualified guess. It was just a wire. The transistor was a 2n5088, but It could be that I just followed R.G. Keens second law: if in doubt, use a 5088 8)
Any ideas?
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
GibsonGM
Very close to the output (recovery) stage of a Big Muff!   The input looks like a 'pre gain' control.  Maybe to be fed with another gain stage or distortion that may output a hot signal?
antonis
Marcos - Munky
#5
Big muff's last stage and lpb are the same but for part's value. The biggest differences are that lpb resistor from base to V+ is 1M, while bm's is 390K-470K, and the resistor from emitter to ground is 390r on lpb and 2K7 on bm. Output cap on lpb is 100nF, while bm's is 100nF-1uF.
So you have basically a bm recovery stage. The first pot looks like some kind of filter.
GibsonGM
I think it could very happily be BOTH!!  :)
cab42
Thanks for the replies.
They triggered my otherwise leaky memory, and I am now pretty sure what it is.
It was an attempt to make a tone control for a JFet Vulcan, consisting of a Stupidly  Wonderful Tonecontrol and a gain recovery stage. I think I nicked the gain stage from the late Ricky Vance's heavy metal pedal, but it had a BMP tonestack.
It was before I got my first breadboard, so I had to put anything on a board in order to experiment. Apparently it did not work out well as it ended in the box and was replaced with a bmp tonestack.
So it was:
Quote from: Marcos - Munky on November 27, 2019, 07:24:53 AM
Now the only mystery left is what happened to the Hogs Foot I was looking for to start with.
Thanks again
Ripthorn
Marcos - Munky
Quote from: cab42 on November 27, 2019, 08:14:10 AM
Yeah, you got a few things at the wrong place. This looks like swtc3 (http://www.muzique.com/news/stupidly-wonderful-tone-control-3/), but you got the resistor and cap at the wrong place and with the wrong values on a power of 10 (cap should be 47n and resistor should be 2k2, that will work but the cut will be at a different frequency than amz's). Easy to solve it - if you want to.
You can easily adapt this one to be a Hogs Foot. Remove everything from the swtc part. Use 3.3uF as the input and output cap. Replace the 100K resistor with a 39K one, and the 2K2 resistor with a 390r one. Add a 100nF cap in parallel with the 10K resistor and another one from base to ground. You can use this schematic as a reference: http://fuzzcentral.ssguitar.com/schematics/moleschem.gif. Well, it's probably easier to just build one from the start  :icon_mrgreen:
cab42
Marcos,
Thanks for the comments.
Yeah, I noticed the errors as well (except for the power of 10). It was a build from my early "career" as a hobby builder, and as such I am not surprised that it did not work.
I want to run the Hogs Foot in parallel with a Bass Fuzz in order to blend in some clean signal. I'm afraid that the clean signal will drown in the gain of the Bazz Fuzz without a booster on the clean signal. I believe it will also fix phase issues as well. I think I'll build the HF on breadboard first. If you saw my vero, you wouldn't try to mod  :icon_rolleyes:
Ripthorn
