Momentary switch on a Buddwah
Started by Stratdude, February 26, 2020, 04:16:35 PM
Stratdude
Hi eveybody, new here.
I have an old Korg wah wich I modded putting a momentary switch on the pedal so it engages as soon as I put my foot on it. Now I wanted to do the same thing on my Buddwah, wich is much more complicated circuitwise. Ordered a switch that look exactly like the original one, 9 poles but is momentary. Took out the original an dsoldered in the new one like the original one. The guitar signal/sound goes to the amp when the switch is not engaged. When engaged the signal is replaced by a tone that changes pitch when I move the pedal up and down. Anyone knows what`s wrong?
patrick398
My first thought was Gilmour. I think he got that 'seagull' sound by connecting his wah back to front. Is it possible you've connected you in and out the wrong way?
EDIT: Also, Welcome to the forum! (Narrowly avoided a slap on the wrist there)
Stratdude
If David did that then certainly I can. Will check. Embarrasing if that's the case.  :icon_biggrin:
Stratdude
Oh. My. God. What a first entry. Cables backwards. Works like a charm. Embarrasing. A weak defence, but the wah is up side down during work. No, doesn`t help :icon_redface:
Well, the problem brought me here anyway. Looking forward to posting and reading.
Ha ha!  Been there, done that...   :icon_rolleyes:  :icon_wink:
Good to have you along for the ride.
Stratdude
Here it is along with my loyal companion the tube screamer.
Quote from: Stratdude on February 27, 2020, 03:19:24 AM
another example of the antipodean remedy. welcome, from the podes.
" I will say no more "
