Replacing the M51134P (as in the DOD Meatbox)
Started by Fancy Lime, March 26, 2020, 03:54:31 PM
Fancy Lime
Hi all,
I have been looking at sub octavers again and particularly the DOD Meatbox and the (not extremely informative) datasheet of the M51134P. I used to think that one had a PPL inside but on closer inspection it seems like it is much simpler. Now unless I am completely off my rocker, it should be fairly easy to build a reasonably close work-alike out of discreet components and a bunch of opamps of CMOS inverters.
Has anyone tried this? Not the most pressing issue in the world, I know, but a modernized better Meatbox-like octavesynth sounds like something I might want. Or is there any modern chip or combination of chips that can replace the M51134P so that I shouldn't bother.
Cheers,
Andy
Nitefly182
This won't help you at this exact moment but Smallbear stocks the M51134P for ~$6 if its just getting the part that concerns you.
Fancy Lime
Quote from: Nitefly182 on March 26, 2020, 04:22:43 PM
No, actually ist's more curiosity how it works. Deconstructing this kind of black-box chip with this kind of vague datasheet into funktional blocks or even discreet components can be quite enlightening.
Andy
Are you familiar with Valvewizard's U-Boat? It's basically what you're describing. I've found the tracking to be a bit better on the M51134P than in other analog sub-octaves, though my experience is limited as I've only ever built one.
Fancy Lime
Quote from: vigilante397 on March 26, 2020, 04:49:28 PM
While I like Merlin's U-boat a lot, the working principle is in some crucial parts very different from the Meatbox.
And
